nunogsm Posted April 5, 2019 Posted April 5, 2019 hello gents, i need some help, after i reinstall the original r1 firmware (R1-v-1-03-6j) i cant find my netduma wi-fi signal, i need to connect to netduma wi-fi to set up my things. any helppp
nunogsm Posted April 5, 2019 Author Posted April 5, 2019 by pressing the reset boton? already do that, prssing that boton, but i cant get wifi signal if i press that botton nothing happens, no bip, no rebot, nothing. and i press 25 / 30 / 40 sec If I connect by cable I have access to internet, but I can’t connect to the interface (192.168.88.1) already clean history/ cookies/ cache
TrayDay Posted April 5, 2019 Posted April 5, 2019 1 hour ago, nunogsm said: If I connect by cable I have access to internet, but I can’t connect to the interface (192.168.88.1) already clean history/ cookies/ cache Try to access the Netduma with 192.168.1.1, you might have reset it completely to factory default and the address might have changed. If you're using windows pc, open CMD or Command Prompt and type "ipconfig" and look for default gateway address, you will find the ip address 192.168.1.1 or 192.168.88.1. This you will use to access netduma.
nunogsm Posted April 5, 2019 Author Posted April 5, 2019 17 minutes ago, TrayDay said: Try to access the Netduma with 192.168.1.1, you might have reset it completely to factory default and the address might have changed. If you're using windows pc, open CMD or Command Prompt and type "ipconfig" and look for default gateway address, you will find the ip address 192.168.1.1 or 192.168.88.1. This you will use to access netduma. Bro you sabe my day with that ip. thankyou one more time
TrayDay Posted April 5, 2019 Posted April 5, 2019 Just now, nunogsm said: Bro you sabe my day with that ip. thankyou one more time Glad was able to help
