CrossFitKila717 Posted December 3, 2018 Posted December 3, 2018 Hey all, im running cat5e cables at the moment between modem/duma/Xbox......I’ve heard that cat6 STP cables are better? Less noise due to the shielding versus the UTP? Will it improve my gaming? Thanks so much!
BIG__DOG Posted December 3, 2018 Posted December 3, 2018 1 hour ago, CrossFitKila717 said: Hey all, im running cat5e cables at the moment between modem/duma/Xbox......I’ve heard that cat6 STP cables are better? Less noise due to the shielding versus the UTP? Will it improve my gaming? Thanks so much! it will do no harm as it helps to eliminate electrical interference that may improve your gaming or it may not! Sorry but I cannot give you a better answer as each persons network connection is unique.
CrossFitKila717 Posted December 4, 2018 Author Posted December 4, 2018 5 hours ago, BIG__DOG said: it will do no harm as it helps to eliminate electrical interference that may improve your gaming or it may not! Sorry but I cannot give you a better answer as each persons network connection is unique. Cool, yea just trying to get the most out of it. So if cat6 is a cleaner signal, may be worth it.
BIG__DOG Posted December 4, 2018 Posted December 4, 2018 8 hours ago, CrossFitKila717 said: Cool, yea just trying to get the most out of it. So if cat6 is a cleaner signal, may be worth it. make sure they are STP.
CrossFitKila717 Posted December 4, 2018 Author Posted December 4, 2018 2 hours ago, BIG__DOG said: make sure they are STP. Do the 5e come in STP?
BIG__DOG Posted December 4, 2018 Posted December 4, 2018 4 hours ago, CrossFitKila717 said: Do the 5e come in STP? yes, I think they do. Category 5 enhanced cabling, also known as Cat5e, is an improvement on Cat5 cabling. It was made to support 1000 Mbps "gigabit" speeds, so in theory, it's faster than Cat5. It it also cuts down on crosstalk, the interference you can sometimes get between wires inside the cable. Both of these improvements mean you're more likely to get fast, reliable speed out of Cat5e cabling compared to Cat5. Butif you are buying new cables it may be a good idea to go for cat6 which are better.
CrossFitKila717 Posted December 4, 2018 Author Posted December 4, 2018 43 minutes ago, BIG__DOG said: yes, I think they do. Category 5 enhanced cabling, also known as Cat5e, is an improvement on Cat5 cabling. It was made to support 1000 Mbps "gigabit" speeds, so in theory, it's faster than Cat5. It it also cuts down on crosstalk, the interference you can sometimes get between wires inside the cable. Both of these improvements mean you're more likely to get fast, reliable speed out of Cat5e cabling compared to Cat5. Butif you are buying new cables it may be a good idea to go for cat6 which are better. Cool, I’m thinking about going Cat 6 for sure but the more I read about the STP, the more I may stick with the UTP version. There’s a lot of talk about having to properly ground that style due to the shielding & if not done properly can cause more issues. Is the STP not grounded within the cable or is it something that has to be done in addition to? Seems like going with just plain ole cat6 as short as possible may be the way to go.....from the modem to duma, and duma to Xbox. I think the one duma sends is a cat5e.
carl0024 Posted December 5, 2018 Posted December 5, 2018 have a look at cat 7 too. might be overkill for gaming but cant hurt if you want the best rig
willieaames Posted December 24, 2018 Posted December 24, 2018 Usually any 100% copper cable is good enough, if yours is CCA (copper clad aluminium) than yeah it is probably junk.
RL317 Posted December 25, 2018 Posted December 25, 2018 I wasn't going to bump this as it had been a while, but someone else bumped it so why not LOL Don't bother with STP unless you're going to ground it. Ungrounded STP acts as an antenna and causes more issues with interference than ungrounded cables. Most CAT7 STP cables are flat low quality crap anyway, so they're pretty contradictory. You can't go wrong with rounded CAT6 or CAT6a U/UTP. I had more issues using FTP (less shielding than STP) than UTP between my modem and router. Also using the ground pins can create a "ground loop" which can cause a fire.
CrossFitKila717 Posted December 27, 2018 Author Posted December 27, 2018 On 12/25/2018 at 12:55 PM, lllRL said: I wasn't going to bump this as it had been a while, but someone else bumped it so why not LOL Don't bother with STP unless you're going to ground it. Ungrounded STP acts as an antenna and causes more issues with interference than ungrounded cables. Most CAT7 STP cables are flat low quality crap anyway, so they're pretty contradictory. You can't go wrong with rounded CAT6 or CAT6a U/UTP. I had more issues using FTP (less shielding than STP) than UTP between my modem and router. Also using the ground pins can create a "ground loop" which can cause a fire. I found brand new, 1 ft long Cat6 cable at work.....about as good as it gets I think! Got one routed from modem to duma, then duma to Xbox.
RL317 Posted December 27, 2018 Posted December 27, 2018 34 minutes ago, CrossFitKila717 said: I found brand new, 1 ft long Cat6 cable at work.....about as good as it gets I think! Got one routed from modem to duma, then duma to Xbox. Yeah shielded cable is unnecessary outside of industrial settings where there's a lot of EMI bouncing around lol
