david Posted November 30, 2018 Posted November 30, 2018 What are the max upload/download speeds I should expect with an R1 running DumoOS? Without R1 I'm getting UP/DOWN speeds of about 400Mbps/20Mbps with R1 I'm getting about 150Mbps/20Mbps. For original R1 OS there were specific config changes to allow higher speeds. Are there any similar settings I should apply to get max throughput for DumoOS?
Administrators Netduma Fraser Posted November 30, 2018 Administrators Posted November 30, 2018 In our lab we've achieved up to 800mbps. However keep in mind thats in a perfect lab environment so real life results will vary substantially. In order to reach closer to your speeds all you should have to do is disable QoS completely in Anti-Bufferbloats settings.
Donovan Posted December 5, 2018 Posted December 5, 2018 On 11/30/2018 at 4:21 PM, Netduma Fraser said: In our lab we've achieved up to 800mbps. However keep in mind thats in a perfect lab environment so real life results will vary substantially. In order to reach closer to your speeds all you should have to do is disable QoS completely in Anti-Bufferbloats settings. I can only get up to 500Mbps with my Internet Giga Speed and my QoS is off with the DumOS Development Milestone 1.3.
Administrators Netduma Fraser Posted December 5, 2018 Administrators Posted December 5, 2018 31 minutes ago, Donovan said: I can only get up to 500Mbps with my Internet Giga Speed and my QoS is off with the DumOS Development Milestone 1.3. That sounds about right to be honest, think you're probably getting the max you can
ggkthx Posted December 22, 2018 Posted December 22, 2018 Any plans to remove the 200Mbps restriction? @Netduma Fraser
Administrators Netduma Admin Posted December 24, 2018 Administrators Posted December 24, 2018 On 12/22/2018 at 1:07 PM, ggkthx said: Any plans to remove the 200Mbps restriction? @Netduma Fraser That's the limit of the R1 hardware with our QoS, so nothing more we can do. If you wanted to achieve QoS at higher speeds then you might want to consider getting the DumaOS powered XR500 or XR700. XR500 has hardware acceleration and the XR700 is just an absolute beast in terms of hardware so they can easily achieve QoS at over 1000mbps.
