need help.
ok under LAN when should I address reserve an IP to my xb1x? is only when I use port forwarding or dmz or should it also be when I use UPNP? I am playing wired.
also should I leave my anti bufferbloat setting on always or on only when high priority is on?
thank you
thank you. I have an open NAT and ping plotter test come back good but I seem to have this very small 1-3ms delay, but I believe taking my xb1x off the address reserve fixed it.
Thanks for letting us know! If there's anything else you need just let us know :D
