HaBlo0 Posted October 12, 2018 Posted October 12, 2018 Hello ! First, sorry for my english, I'm french, i'm gonna try to explain the best I can 😛 So I did the update on DumaOs ; I try to change language but I see that I have not the globe icon at the top right of the interface, like what I see on xr500 video settings (same thing on network settings, i don't have the same display.. Is it normal ? thank you !
Administrators Netduma Iain Posted October 12, 2018 Administrators Posted October 12, 2018 Hi, Hope you're enjoying DumaOS. The r1 version doesn't currently have language support. Sorry about that.
Administrators Netduma Admin Posted October 12, 2018 Administrators Posted October 12, 2018 Hi HaBloo - we will be looking to add translations to the R1 in the future. It's good to know you would find this useful. For now, I recommend using the interface in Google Chrome and translating the page to French if that is easier than reading the English. Thanks for letting us know.
HaBlo0 Posted October 12, 2018 Author Posted October 12, 2018 Okay and for the menu settings ? will it be the same that on the xr500 ? And for the moment, it works great, my ping is more stable than in the r1 and the host filtering too ! thks !
Administrators Netduma Admin Posted October 12, 2018 Administrators Posted October 12, 2018 Which menu settings exactly? Do you mean the 'Network Settings' section? This will not be the same as XR500 settings are NETGEAR's code, so we have our own version on the R1 Really great to hear you are enjoying it. Thank you for your support
HaBlo0 Posted October 12, 2018 Author Posted October 12, 2018 Yes this is it.. Okay, meaning is good because it's easier, but on the other, it seems less complete ^^ But for the moment, this is very good ! thks for this work I'm gonna try this on WW2 cause i spent 12h on it, I will better see the difference (I think). Little question, on QOS, is it better to enable antibufferbloat "always" or "when high priority.." ? I tick when high priority for the moment
Administrators Netduma Admin Posted October 12, 2018 Administrators Posted October 12, 2018 I recommend High Priority because it only enables Anti-Bufferbloat when you need it (when you are playing games)
HaBlo0 Posted October 12, 2018 Author Posted October 12, 2018 Okay thank you ! we will see if it was worth the wait 😁
Administrators Netduma Admin Posted October 12, 2018 Administrators Posted October 12, 2018 2 hours ago, HaBlo0 said: Okay thank you ! we will see if it was worth the wait 😁 ❤️
