Spectrals Posted June 13, 2018 Posted June 13, 2018 so basically i got a new xr500 and i’m trying to connect it to the modem to set it up as my main router but i’m having problems detecting the internet connection? i keep trying to no success but when i connect to my ac88u everything works fine and its able to detect the internet connection. i connected the xr500 to my ac88u and it worked but the connection is really slow to the point i can’t load anything. fyi i’m trying to connect my xr500 to my modem as my main router and use my ac88u as a repeater/ap. pls help plox
BIG__DOG Posted June 13, 2018 Posted June 13, 2018 Can you tell us what modem you are using and your isp? Is it a modem or a modem/router?
Spectrals Posted June 13, 2018 Author Posted June 13, 2018 it is a modem/gpon terminal provided by my ISP, UniFi (i live in malaysia) Huawei HG8240w
BIG__DOG Posted June 13, 2018 Posted June 13, 2018 If you are using a modem then the ethernet cable goes from your modem into your WAN port of the XR500 and then connect your laptop/pc to lan1 of the XR500, do not configure wirelessly to avoid a connection drop if there is any updates. To access the XR500 enter the url 192.168.1.1 or http://routerlogin.comto access your XR500 user interface.
Administrators Netduma Fraser Posted June 13, 2018 Administrators Posted June 13, 2018 Sounds like you probably need PPPoE, just to double check have a look at the other routers WAN settings and see what it has there then mirror than on the XR500. Though as it is working you may just need to input the speeds you have into anti-bufferbloats options.
Spectrals Posted June 13, 2018 Author Posted June 13, 2018 i entered my pppoe details and still couldn’t detect the internet connection from my modem though
e38BimmerFN Posted June 13, 2018 Posted June 13, 2018 Is the ISP modem using the same Ip address 192.168.1.1 by chance? This is the same default address that any NG router uses and could be conflicting. Initial set up and walking the setup wizard should correct for this possibility. You can change it on the XR router manually to something different, try 192.168.88.1 or 192.168.0.1 on the XR router,
Blameless Posted June 13, 2018 Posted June 13, 2018 I've been having a problem with my xr500!! I notice that my labtop & xbox wont connect to the internet unless I reboot the router & I have to do it every morning!! But the funny thing is that the wifi works I have no problem with it!
Administrators Netduma Fraser Posted June 13, 2018 Administrators Posted June 13, 2018 I've been having a problem with my xr500!! I notice that my labtop & xbox wont connect to the internet unless I reboot the router & I have to do it every morning!! But the funny thing is that the wifi works I have no problem with it! Hi Blameless, can you make a new topic regarding your issue please and we can help you there, its hard to help you properly as you're posting in other peoples topics
