sharpz44 Posted March 29, 2018 Posted March 29, 2018 When setting the traffic to manual for ps4 and battlefield it seems the priority red icon is not showing,I’m using it with Duma classified unticked as only want ps4 and not daughters laptop running roblox etc ,this is set to when detected,works when I re tick Duma class though. Did this as spotted big dogs post about using it this way
Administrators Netduma Fraser Posted March 29, 2018 Administrators Posted March 29, 2018 For consoles select the games console service rather than any other service like Battlefield and should work just fine!
sharpz44 Posted March 29, 2018 Author Posted March 29, 2018 For consoles select the games console service rather than any other service like Battlefield and should work just fine! I see,ok great that works,though shows as Xbox but that’s fine as that’s a console ...lol....cheers once again
Administrators Netduma Fraser Posted March 29, 2018 Administrators Posted March 29, 2018 I see,ok great that works,though shows as Xbox but that’s fine as that’s a console ...lol....cheers once again Yep that's just a typo, it will work for both consoles!
BIG__DOG Posted March 30, 2018 Posted March 30, 2018 yeah bud, it does show as xbox but do not worry. I don't use any games selected, just ps4 and xbox and then select games console. I have both consoles so I don't confuse you.
sharpz44 Posted March 30, 2018 Author Posted March 30, 2018 yeah bud, it does show as xbox but do not worry. I don't use any games selected, just ps4 and xbox and then select games console. I have both consoles so I don't confuse you. Yer same I have both ,I have noticed something strange if increaseing distribution and doing a Speedtest it drops on DL to 48 which it should but then resetting and updating it stays the same,did a reboot last night and was back up to 73 after with 70/70 sliders and nothing running,actually done this twice now , think there’s a bug in there or something as on a few other occasions it was fine , anyway I’m leaving it set equally now as that’s fine like that.
BIG__DOG Posted March 30, 2018 Posted March 30, 2018 i have mine set to 70/70 and "always" enabled. I have more than enough bandwidth for what I need and if downloading large files tames a bit longer then so be it as I don't want to adjust mine.
Administrators Netduma Fraser Posted March 30, 2018 Administrators Posted March 30, 2018 Yer same I have both ,I have noticed something strange if increaseing distribution and doing a Speedtest it drops on DL to 48 which it should but then resetting and updating it stays the same,did a reboot last night and was back up to 73 after with 70/70 sliders and nothing running,actually done this twice now , think there’s a bug in there or something as on a few other occasions it was fine , anyway I’m leaving it set equally now as that’s fine like that. Likely something to do with high priority & share excess on/off. If you can produce reproducible steps though to confirm you've found an issue that'd be very helpful.
sharpz44 Posted March 30, 2018 Author Posted March 30, 2018 Likely something to do with high priority & share excess on/off. If you can produce reproducible steps though to confirm you've found an issue that'd be very helpful. Think I’ll do it when I get back from working as go back to oil rig Sunday so going to leave it be so no issue when away,but I will reproduce when I’m back in 3 weeks.
sharpz44 Posted March 30, 2018 Author Posted March 30, 2018 i have mine set to 70/70 and "always" enabled. I have more than enough bandwidth for what I need and if downloading large files tames a bit longer then so be it as I don't want to adjust mine. I agree ,I have mine when detected as daughters always on Sims,robloxs,minecraft on her pc ,hence why I changed it to just consoles that way when she’s on and we want to watch nexflix it runs great and my connection is good @ a constant 73 ish as I’m near exchange,also just did up gaming room and I get better connection with XR than I did with Rog rapture,big expensive upside dowm spider in a box ...lol...probs turn into a tarantula...lol
