ViciousSavag3 Posted March 27, 2018 Posted March 27, 2018 So guys ive been having this major issue that is so frustrating i kinda tried everything i can and still doesnt work on making my Slow Upload speed better on my ps4 can anyone help me on this please. My download speed suppose to be 250 Down and 10 up but i only get like 80 down and 1 up WHY? ANY SOLUTIONS to this?
BIG__DOG Posted March 27, 2018 Posted March 27, 2018 your upload and download speeds if tested on the ps4 are never right. that is just the nature of using a console to do a speed test. Do not worry about it so long as when you do a speed test on a pc wired to the router that it is correct.
ViciousSavag3 Posted March 27, 2018 Author Posted March 27, 2018 ohhh ok sounds good.. very true tho thank you so if the game or the ps4 starts acting really slow what would be the problem there? like with glitching or slow reacting?
II Z IE IR O II Posted March 27, 2018 Posted March 27, 2018 your upload and download speeds if tested on the ps4 are never right. that is just the nature of using a console to do a speed test. Do not worry about it so long as when you do a speed test on a pc wired to the router that it is correct. agreed! Its never right. It actually reports very slow both the download /upload
Netduma Staff Netduma Jack Posted March 28, 2018 Netduma Staff Posted March 28, 2018 ohhh ok sounds good.. very true tho thank you so if the game or the ps4 starts acting really slow what would be the problem there? like with glitching or slow reacting? Yep this is true - consoles lack the necessary software to perform accurate speed tests. If it feels like it takes a while for your button press to register in the game, that could be input delay. This can be caused by playing over WiFi, playing on a wireless controller or using a TV rather than a gaming monitor. It could also be performance issues, notably if your framerate drops or the game renders in a glitchy way. If it's bad hit registration that can be simply down to the game net-code and how the game handles lag compensation, which will feel worse or better depending on the game you're playing and in some cases your ping. Lag is separate, and manifests in your character feeling sluggish / rubber banding and large delays between your action and the games reaction. This is what the R1 is working to eliminate I hope this helps!
