ItsIVIarcus Posted February 11, 2018 Posted February 11, 2018 hey netduma forum support i have the netduma r1 im in uk an im sky fibre max with sky q hub then my r1 connect to it i cant get it to work right with ww2 on ps4 ive been trying all different setting for months i need your help on how to setup it up right
BIG__DOG Posted February 11, 2018 Posted February 11, 2018 well, for starteres we need to know what you mean by you can't get it to work right! We need to know what the problem is that you are having. I have the ps4 with WW2 and I can tell you that that game is totally crap on the ps4 but is awesome on the xbox. There's something fundamentally wrong with that game and I am not the only 1 with that opinion.   B.D
RADDY1993 Posted February 11, 2018 Posted February 11, 2018 hey netduma forum support i have the netduma r1 im in uk an im sky fibre max with sky q hub then my r1 connect to it i cant get it to work right with ww2 on ps4 ive been trying all different setting for months i need your help on how to setup it up right I have the exact same setup as you, heres how i connect mine http://forum.netduma.com/topic/2111-how-to-set-up-the-netduma-with-sky-fibre-sr-102-modemrouter/
pollutionblues Posted February 11, 2018 Posted February 11, 2018 hey netduma forum support i have the netduma r1 im in uk an im sky fibre max with sky q hub then my r1 connect to it i cant get it to work right with ww2 on ps4 ive been trying all different setting for months i need your help on how to setup it up right Hi,  Welcome to the forum.  Can you be a bit more specific about your issue please? It will be easier to troubleshoot if we know what isn’t working for you.
ItsIVIarcus Posted February 11, 2018 Author Posted February 11, 2018 Hi,  Welcome to the forum.  Can you be a bit more specific about your issue please? It will be easier to troubleshoot if we know what isn’t working for you. it takes ages to find a game an when it does im always on red bar connection
pollutionblues Posted February 11, 2018 Posted February 11, 2018 it takes ages to find a game an when it does im always on red bar connection Ok, try this for starters.  Set geo filter to 1000km Set ping assist to 0 Untick strict mode Set the Anti Flood sliders both set to 70% Put your PS4 into Hyper-Traffic  Do you have an open NAT in game?  If it still takes a while to find a game and you are still on a red bar then it’s possible you might have an issue with your line. Let us know how those settings go first and then we can take it from there.
Administrators Netduma Fraser Posted February 11, 2018 Administrators Posted February 11, 2018 Can you provide the screenshots asked for here please:Â http://support.netduma.com/support/solutions/articles/16000022425-lag-support-instructions-to-post-on-the-forum-
