Limited connection while using netduma
Hello,
I have an issue while using the netduma, when i'm connected directly to my box (BBOXv3 from Proximus ( i'm from belgium)), i have ~63-65Mbps but if i use the netduma, i only have ~20Mbps.
My box have 2 Wi-Fi, 2.4Ghz and 5Ghz. I know netduma only have 2.4Ghz, but i got 63-65Mbps with the two Wi-Fi with my box.
My ISP use PPPOE, i have user and password, i tryied to use it in the netduma, But settings does not save when I press the "Apply" button, he just refresh the page.
My problem may be unclear, i speak english very bad. I know i can use the French forum but yeah :c
I can explain in french if you don't understand me. :)
If you need more information, tell me !
make sure you are using the reactive option in congestion control.
You could enable turbo mode my isp said I get 100 down but with turbo I max out at 150 just saying and even if you don't wanna see if you can get more out of turbo you can just leave your current settings as is and enable turbo to get close to your down speed or exactly it
Ok, settings are ok now.
But now i have ~40Mbps and not 60
There's some great advice above, but try out these settings as well:
- Reactive Algorithm
- 100% anti-flood
- Share excess enabled
- Reset device prioritisation & apply
- Disable IPv6 in WAN, LAN & misc
- Disable deep packet in misc
- Ensure the ethernet cables you're using connecting the R1 to hub & R1 to PC are Cat5e+/can handle your speeds.
- Do a wired speed test from a PC
Try playing around with the Anti-flood sliders as well, it's often possible to find a sweet spot where you can achieve higher speeds. Don't be afraid to try out different settings - though I would say the settings I just suggested will be your best bet.
