Wired Connection.
Got strict on wired connection. How do I solve this one? Thanks
More information about your setup would help. I would recommend checking out this guide which should have the solution in most cases: http://support.netduma.com/support/solutions/articles/16000022359-how-do-i-open-my-nat-
Let us know how you get on.
Are you gaming on PC, PS, or XBone?
Do you get strict on all games or just particular games?
Sorry about that. Have HP touch computer, modem and screen in unit. Wired into Router, Ubee Dvw326. Has wifi for wireless phone. That's wired into Netduma. This is all, into two separate PS4 consoles.( never played at same time) Sometimes wired, sometimes wifi.
Is it on the game itself or the console itself saying the NAT is strict? Did you follow the guide provided by Jack?
Gotcha, the game may be showing an incorrect reading. Disable the Geo-filter before starting if port forwarding doesn't help.
