3zo000oz Posted April 26, 2017 Posted April 26, 2017 hello, i have this speed issue for a week now, i have my full speed on the router then after 1 or 2 days the speed drops from 300 down and 150 up to 90 down and 90 up i then reset the router to factory default settings and then i apply my settings to the router and the router works fine again and after 1 or 2 days i get the same problem again my speed drops and i have to reset the router to get my full speed i'm not sure what is the problem but it looks like i have to reset the router every few days to get my full speed thanks for the help in advance
iAmMoDBoX Posted April 26, 2017 Posted April 26, 2017 hello, i have this speed issue for a week now, i have my full speed on the router then after 1 or 2 days the speed drops from 300 down and 150 up to 90 down and 90 up i then reset the router to factory default settings and then i apply my settings to the router and the router works fine again and after 1 or 2 days i get the same problem again my speed drops and i have to reset the router to get my full speed i'm not sure what is the problem but it looks like i have to reset the router every few days to get my full speed thanks for the help in advance What modem do you have? Sounds like the EEE bug to me.
3zo000oz Posted April 26, 2017 Author Posted April 26, 2017 Do you have cookies ticked in misc settings? Yes
3zo000oz Posted April 26, 2017 Author Posted April 26, 2017 What modem do you have? Sounds like the EEE bug to me. This from the router page Manufacturer:Huawei Technologies Co., Ltd; ProductClass:HG8244T
iAmMoDBoX Posted April 26, 2017 Posted April 26, 2017 This from the router page Manufacturer:Huawei Technologies Co., Ltd; ProductClass:HG8244T Can't really find any info on that modem. it seems to be very uncommon
Administrators Netduma Fraser Posted April 27, 2017 Administrators Posted April 27, 2017 Have you done a test directly from the Huawei to see if the speeds drop when using that without the Duma connected?
3zo000oz Posted April 27, 2017 Author Posted April 27, 2017 Have you done a test directly from the Huawei to see if the speeds drop when using that without the Duma connected? can't do that cuz the modem on another room and i don't have a laptop to do it is there anything else i can try?
Administrators Netduma Fraser Posted April 28, 2017 Administrators Posted April 28, 2017 can't do that cuz the modem on another room and i don't have a laptop to do it is there anything else i can try? Well that is the easiest way to confirm either way whether it's the Duma or not causing the issue. Does it happen during peak times or randomly? Do you have settings done for max speed at the time when speed is reduced? Just as a reminder: Reactive Algorithm 100% anti-flood Share excess enabled Reset device prioritisation & apply Disable IPv6 in WAN, LAN & misc Disable deep packet in misc Enable turbo mode Ensure the ethernet cables you're using connecting the R1 to hub & R1 to PC are Cat5e+/can handle your speeds. Do a wired speed test from a PC
3zo000oz Posted April 28, 2017 Author Posted April 28, 2017 Well that is the easiest way to confirm either way whether it's the Duma or not causing the issue. Does it happen during peak times or randomly? Do you have settings done for max speed at the time when speed is reduced? Just as a reminder: Reactive Algorithm 100% anti-flood Share excess enabled Reset device prioritisation & apply Disable IPv6 in WAN, LAN & misc Disable deep packet in misc Enable turbo mode Ensure the ethernet cables you're using connecting the R1 to hub & R1 to PC are Cat5e+/can handle your speeds. Do a wired speed test from a PC it is random and yes i checked the settings before i reset to factory defaults yesterday i got the same problem but a normal reboot fixed the speed issue but sometimes normal reboot dose not fix the issue, and if i reboot manually by switching duma off and on it resets all the settings to defaults
Administrators Netduma Fraser Posted April 29, 2017 Administrators Posted April 29, 2017 I can do a 1 on 1 on Tuesday, so when the speed drops again don't reboot, factory reset etc so I can take a look while it's happening. Post in the 1 on 1 section: http://forum.netduma.com/forum/66-request-1-on-1/ Please read this first before making the post: http://forum.netduma.com/topic/11450-read-before-posting-a-1-on-1-request/
3zo000oz Posted April 30, 2017 Author Posted April 30, 2017 I can do a 1 on 1 on Tuesday, so when the speed drops again don't reboot, factory reset etc so I can take a look while it's happening. Post in the 1 on 1 section: http://forum.netduma.com/forum/66-request-1-on-1/ Please read this first before making the post: http://forum.netduma.com/topic/11450-read-before-posting-a-1-on-1-request/ i have the problem now but i have to reset the router cuz my brother needs to play online i will post on the 1 on 1 forum but i can't grantee the problem will happen when we will be on the 1 on 1
