SpicyGerman Posted January 14, 2017 Posted January 14, 2017 So I was doing settings on netduma I blocked the computer from the control settings so my Xbox one would get all the power and after that and turning off wifi settings I got disconnected and I can't connect to the netduma wifi. I screwed myself and I can't get refund because I've had it longer than a month. Any suggestions?
iAmMoDBoX Posted January 14, 2017 Posted January 14, 2017 So I was doing settings on netduma I blocked the computer from the control settings so my Xbox one would get all the power and after that and turning off wifi settings I got disconnected and I can't connect to the netduma wifi. I screwed myself and I can't get refund because I've had it longer than a month. Any suggestions? Unblock the computer from the xbox using the browser or factory reset it with the button on the back
SpicyGerman Posted January 14, 2017 Author Posted January 14, 2017 Ever since this happened I can't connect to netduma through wifi. Because the wifi is off through settings
belly120 Posted January 14, 2017 Posted January 14, 2017 connect to the netduma using a lan cable to bypass the wifi issue
Administrators Netduma Fraser Posted January 14, 2017 Administrators Posted January 14, 2017 Hey, welcome to the forum! Either reset it using the button in the back, in which case the password will be "netdumar1" or connect via ethernet and change the settings.
Netduma Staff Netduma Jack Posted January 18, 2017 Netduma Staff Posted January 18, 2017 Ever since this happened I can't connect to netduma through wifi. Because the wifi is off through settings Hey, just wanted to check if your issue has been resolved? We're happy to help you solve it if not.
