pc connection problem
this has happened out of the blue my desktop wont connect to the internet , its telling me that local area connection doesnt have a valid ip configuration.
i upgraded to windows 10 5 or 6 months ago plugged it in and everything was fine now this has happened out of the blue.
my ps4 is wired that connects through the r1 my laptop is wifi that connects through the r1 as does my fone.
my desktop is linked to the r1 then my isp router then into the fttc hub.
the windows trouble shooter cant fix this it just tells me the local area etc.
anyone got any thoughts/ideas ?,
I think it has something to do with a bug in the new Windows 10 update that just came out.  If you recently updated windows 10 this is probably why.  It happened to me and I called my isp and they just had me do a few simple commands in the command prompt window and it worked.  Basically flushed my DNS cache I believe?  If you google windows 10 update bug invalid ip you'll find a work around if you don't want to call your isp.
Glad to see the problem was solved; it's the first I've heard of that Windows 10 bug. Cheers Mas7er Broda :)
Apparently it's been doing the rounds for a while.
If you run into the same problem again, try this below (it works 99% of the time for me):
Press windows button + 'X' on the keyboard, choose "Command prompt (admin)". Type netsh winsock reset press enter, then type netsh int ip reset and press enter.
You can close the prompt and it should fix the problem. If not you could open another command prompt screen and go through the ipconfig /release, /flushdns, /renew etc.
