TurboBaron Posted December 20, 2016 Posted December 20, 2016 So I've got a problem with my congestion control screen. When I click on the tab this is what I see (as opposed to the diagram where you can drag the bandwidth to allocate it). Anyone had this before that can recommend a fix ?
BENORMOUS Posted December 20, 2016 Posted December 20, 2016 I'd first try rebooting the duma,if that's doesn't fix it unplug the duma for 5 mins then retry
Administrators Netduma Fraser Posted December 20, 2016 Administrators Posted December 20, 2016 It is likely something on your browser, I can't maximise the picture but disable any adblock things like that then hard refresh the page.
TurboBaron Posted December 20, 2016 Author Posted December 20, 2016 OK guys so I tried rebooting the router through settings -> Misc, that didn't work. Also tried unplugging the router and leaving it for a good 10 mins, still had the same problem. I disabled all of my active extensions in Chrome, closed Chrome down and re-opened it, then hard refreshed a tab with the Congestion Control page on and I'm still having the same issue. I'm seeing the same thing if I use Safari as well.
Netduma Staff Netduma Jack Posted December 20, 2016 Netduma Staff Posted December 20, 2016 Please make a post in the 1 on 1 section of the forum and Fraser will take a look; it's an issue we haven't come across before, and changing browser would usually solve these sorts of problems.
