KYZA-SOZAY82 Posted December 7, 2016 Posted December 7, 2016 I've been having problems for a few hours now,i keep getting disconnected from all my games on my ps4,its saying server connection lost, I've checked my connection on the netduma and it says its perfect,its the same on the psn test network but i havnt changed anything. I've rebooted everything,signed in and out of psn turned ps4 off and on but cant connect to online gameplay. PLEASE HELP Gaming is all i do:(
KYZA-SOZAY82 Posted December 7, 2016 Author Posted December 7, 2016 I connect but shortly after it looses connection
iAmMoDBoX Posted December 7, 2016 Posted December 7, 2016 Do you hear the netduma rebooting when this happens? Could be over heating
KYZA-SOZAY82 Posted December 7, 2016 Author Posted December 7, 2016 No i think its my old router which is plugged into the BT openreach thing,i plug the netduma into old router and it was working fine. I just unplugged my netduma and i am just using old router but problem still haopining. Maybe its my ISP or my PS4?
ColonicBoom Posted December 7, 2016 Posted December 7, 2016 Do you need to have this extra 'old' router in the chain? Can you detail your setup please? My setup, for example, would be... TalkTalk HG633 (ISP hub/modem combo) > Netduma > Asus RT-N66U (as a wireless access point). To find out if there are problems with your ISP line: Download Ping Plotter and run a decent length test (an hour or so) with it, while your computer is connected straight to your ISP hub / modem with an ethernet cable (while nobody is using your connection). Run the test to a large local server, like a national news website or Twitter if you're in the States. Screenshot the resulting graph and post it up here for us to have a look at. Make sure you right click the graph at the bottom and change the display to show an hour or so rather than the default 1 minute (because 1 minute will tell us nothing).
KYZA-SOZAY82 Posted December 8, 2016 Author Posted December 8, 2016 Its working perfectly now i woke up put ps4 on and it is working now,i noticed that some of my settings on my netduma had been changed like upnp was unticked maybe thats what it was? If somebody remotely accessed my netduma THANKS. Thanks to the netduma wizard lol.
Administrators Netduma Fraser Posted December 8, 2016 Administrators Posted December 8, 2016 No one accessed your router but great to hear its working. I'll close this thread now. Feel free to open another if needed.
