KYZA-SOZAY82 Posted November 18, 2016 Posted November 18, 2016 Why do i keep being connected to hosts outside my geo filter and it comes up as allowed host but i havnt allowed any1 outside of it and been working fine since i first started using my netduma about 3 days ago. Ive been playing on pro evolution soccer 17 and it was working perfectly until now. Any help would be greatly appreciated thanks.
bagsta69 Posted November 18, 2016 Posted November 18, 2016 Do you have ping assist ticked and a value? If you do the R1 will still connect you to hosts outside of your radius if they are under your PA threshold.
KYZA-SOZAY82 Posted November 18, 2016 Author Posted November 18, 2016 Yes i do ill try unticking it when i next play. Thank you for the help mate.
KYZA-SOZAY82 Posted November 18, 2016 Author Posted November 18, 2016 Which is ping assist,PEER PING or auto ping host???
ColonicBoom Posted November 18, 2016 Posted November 18, 2016 Neither. It's the slider that says 'Ping Assist'. Set it to zero if you want to disable it.
Administrators Netduma Fraser Posted November 19, 2016 Administrators Posted November 19, 2016 Strict mode on, ping assist 0 will mean no games outside your radius.
