Axeman747 Posted October 10, 2016 Posted October 10, 2016 I set the congestion control, I go to Host Filter then go back to double check my settings and they are right. However after 30-40 minutes of gaming I go back to congestion control and the values are different, sometimes only a few points sometimes all the way back to 100%.
BIG__DOG Posted October 11, 2016 Posted October 11, 2016 yeah, make sure cookies are enabled in misc settings or any changes you make will not be applied!
Administrators Netduma Fraser Posted October 11, 2016 Administrators Posted October 11, 2016 As above, also make sure you're using Google Chrome/Firefox to view the interface.
ColonicBoom Posted October 11, 2016 Posted October 11, 2016 You need cookies enabled. But if you log in using a different browser or a different profile on your browser then it can pull the information from separate cookies (I think) so you can end up with changed settings because it has pulled old settings from when you were previously using that other profile.
Axeman747 Posted October 11, 2016 Author Posted October 11, 2016 Thanks all. I'll double check my settings
