need help setting my netduma up properly
Jettman
hey i was talking to duma earlier on twitter about maybe my Netduma not being straight up connect to the isp hub however my Netduma is connected to the neg-ear nighthawk but it is a modem/router any help to set it up properly
Should be ISP hub > duma (all devices) > then any other router if you want to make the most of the R1's features
  • 2 weeks later...
You should have a modem which was given to you by your Internet provider. The Netduma should be connected to it, and then everything else should connect to the Netduma for the best results.
