3zo000oz Posted October 3, 2016 Posted October 3, 2016 Hello I'm on the latest firmware And i had this issue for few weeks now Everytime i restart duma from the i lose my settings and i have to configure the settings again The only thing stays is the wifi password And i reset duma by unpluging the power cable because sometimes I can't access the duma until i do that Is there something wrong with my router or is known issue? Thanks
ColonicBoom Posted October 3, 2016 Posted October 3, 2016 This a known RTFM problem. If you enable cookies in 'miscellaneous settings' it will resolve the issue of your settings not saving. You should reboot the router from 'miscellaneous settings' too. If you can't connect over wifi (which is probably also a setup issue) then you should be able to by ethernet.
BIG__DOG Posted October 3, 2016 Posted October 3, 2016 the only reason the wifi password is saved because it is stored in your browsers cache. Reconfigure the netduma to the settings you desire and then go to profiles and save your custom profile ticking all the boxes required so that if you need to wipe the duma again in the future you can apply all your settings via the saved profile you created!
Administrators Netduma Fraser Posted October 3, 2016 Administrators Posted October 3, 2016 As above, you should always be rebooting via the button in miscellaneous settings. Cookies on in misc settings also. Would also recommend saving a profile or your settings then exporting them so you can import them if needed.
3zo000oz Posted October 3, 2016 Author Posted October 3, 2016 Thanks guys for the info It is easy to configure the duma but i thought it was a problem with my router but since it is known issue then no problem at all
