tellto Posted August 3, 2016 Posted August 3, 2016 so what i did is that i disabled my geo filter so my friend could join me and after he did, i added him to my allow list and then enabled my geofilter back again. now im trying to invite him and its showing the same problem why?
Administrators Netduma Fraser Posted August 3, 2016 Administrators Posted August 3, 2016 Where there multiple circles that popped up when you disabled the Geo-filter and he joined? If possible you may have allowed the wrong one. When did you try to invite him again, at a later date? If so it's possible his IP changed so you will need to add him again.
frustrated Posted August 3, 2016 Posted August 3, 2016 Hi,yeah I have a funny issue where if I pick on the allow list I can see my friend,but when I have my friend in the Geo the red circle isn't her (Id).So I check the Id and it's odd as when she is in my Geo it's a different (id) So I'm confused why her Id is changed.Maybe the same if not similar to above.
fuzzy clam Posted August 3, 2016 Posted August 3, 2016 so what i did is that i disabled my geo filter so my friend could join me and after he did, i added him to my allow list and then enabled my geofilter back again. now im trying to invite him and its showing the same problem why? The easiest way to make sure your actually adding your friend to your allow list is to invite him to a private match,that way it's just one circle on your GF and rate him 100 %,update and you should be all set. Sometime if there are a lot of players (circles) on your GF close to your friend's location it's easy to click the wrong circle and allow them instead of your friend.
tellto Posted August 3, 2016 Author Posted August 3, 2016 dynamic IP will cause this yeah i invited him to a private party and i added him but it didnt work for some reason at a later date. that day it worked fine
tellto Posted August 3, 2016 Author Posted August 3, 2016 Where there multiple circles that popped up when you disabled the Geo-filter and he joined? If possible you may have allowed the wrong one. When did you try to invite him again, at a later date? If so it's possible his IP changed so you will need to add him again. yeah i invited him to a private party and i added him but it didnt work for some reason at a later date. that day it worked fine. and there was only 1 circle and i know where he lives so i made sure that was the right circle
tellto Posted August 3, 2016 Author Posted August 3, 2016 Where there multiple circles that popped up when you disabled the Geo-filter and he joined? If possible you may have allowed the wrong one. When did you try to invite him again, at a later date? If so it's possible his IP changed so you will need to add him again. i dont think his ip changed because i invited him again in a private party and when i clicked on the same circle, it said "temp ban" so i think its the same circle i added
Administrators Netduma Fraser Posted August 4, 2016 Administrators Posted August 4, 2016 yeah i invited him to a private party and i added him but it didnt work for some reason at a later date. that day it worked fine. and there was only 1 circle and i know where he lives so i made sure that was the right circle That definitely sounds like his IP changed then. i dont think his ip changed because i invited him again in a private party and when i clicked on the same circle, it said "temp ban" so i think its the same circle i added Temp ban dictates that it is a dedicated server so that won't have been him
