Mutilatorz Posted June 21, 2016 Posted June 21, 2016 I honestly don't know what to do and I'm about to scrap this NETDUMA. I see videos of everyone having a blast with their connection but I'm still lagging and rubber-banding. XBONE Black Ops 3, Wired, Open NAT, I've followed the tutorials found here. http://wiki.netduma.com/doku.php?id=fine_tune_netduma http://wiki.netduma.com/doku.php?id=user_manual To no avail. I don't even like to play Multiplayer anymore because of how horrible it is. If I connect my Xbox directly to my modem or netgear router I get a better experience. ATT Broadband Connection 25/5 Modem in BRIDGE MODE Netduma XBOX ONE (Open NAT) One with most issues PS4 (Type 2) XBOX ONE (Moderate NAT) 8-port Netgear Dumb Switch Netgear Router (for WIFI Access ONLY) Printer Printer STB I really need some help here.
PharmDawgg Posted June 21, 2016 Posted June 21, 2016 Run internet diagnosis which is on the router's interface. Then post the results and details here so that we may be able to analyze your actual connection.
Netduma Staff Netduma Jack Posted June 21, 2016 Netduma Staff Posted June 21, 2016 Hey, welcome to the forum! You definitely don't have it set up correctly if you're getting a better experience without the duma. Please provide us with the screenshots from this link so we can more easily help you http://wiki.netduma.com/doku.php?id=lag_support_instructions
fuzzy clam Posted June 21, 2016 Posted June 21, 2016 As said above run Internet Diagnosis on the duma and I would also download and run ping plotter at peak hours to make sure your ISP isn't the issue.
Mutilatorz Posted June 22, 2016 Author Posted June 22, 2016 Internet Diagnostics Page Host Filtering Geo Filter Congestion Control (Same for Download/Upload) Ping Graph Sorry I made a mistake on my OP my Paid connection is 25 mbps download 3 mbps upload. Thank you guys for the support.
Netduma Staff Netduma Jack Posted June 22, 2016 Netduma Staff Posted June 22, 2016 Firstly, click show details beneath your internet diagnosis; this will allow you to see your base ping. It could be possible that the ping you are receiving in games is as good as possible for your base ping. I'm assuming you're using "Sparkys Xbox One"; if not, with the other two devices, you need to select the none PA service for the devices, as the PA versions are obsolete. If you are using those devices, enable them. You could also turn on strict mode, and turn your distance slider to 1000km and your Ping Assist slider to 0. This will ensure that you only connect to hosts within the radius. On Congestion Control, you should reset the device prioritisation, and turn on hyper traffic for your console. Overall though, it appears that the Netduma is doing it's job, as your average ping being 31ms is very good; you shouldn't be getting rubber banding or frame drops with such a good ping.
Urge Posted June 22, 2016 Posted June 22, 2016 Firstly, click show details beneath your internet diagnosis; this will allow you to see your base ping. It could be possible that the ping you are receiving in games is as good as possible for your base ping. I'm assuming you're using "Sparkys Xbox One"; if not, with the other two devices, you need to select the none PA service for the devices, as the PA versions are obsolete. If you are using those devices, enable them. You could also turn on strict mode, and turn your distance slider to 1000km and your Ping Assist slider to 0. This will ensure that you only connect to hosts within the radius. On Congestion Control, you should reset the device prioritisation, and turn on hyper traffic for your console. Overall though, it appears that the Netduma is doing it's job, as your average ping being 31ms is very good; you shouldn't be getting rubber banding or frame drops with such a good ping. We all see a little of that at times. I think people are thinking it's the router when it's another issue. If I see that stuff - it is always another peer from further away that is bogging down the lobby. The distance doesn't matter at all but the peer's internet is so crappy that they are red barring and fluctuating. Even yellow fluctuating bars that keep going yellow, green, yellow consistently will do it. IMO, people can have great connections and think the router ends 'all' lag period; but nothing anyone can do about a peer joining the dedi while playing on an internet in the Dollar Store pantry closet.
PharmDawgg Posted June 23, 2016 Posted June 23, 2016 May be try decreasing your geofilter . Your losing some of your geofilter over the ocean. Honestly I don't even use the geofilter. I set my geofilter a small as possible and set ping assist to my base ping +10ms. And then I'm good. Ping > Geofilter. Geofilter don't mean much when someone is within your radius with a crazy high ping. Always enable strict mode too. It is not God Mode but it's good enough for me.
Mutilatorz Posted June 23, 2016 Author Posted June 23, 2016 @Buck Nasssty, I have my Geo-Filter here because this way I eliminate the chances of connecting to East Coast Hosts with Fiber. Firstly, click show details beneath your internet diagnosis; this will allow you to see your base ping. It could be possible that the ping you are receiving in games is as good as possible for your base ping. I'm assuming you're using "Sparkys Xbox One"; if not, with the other two devices, you need to select the none PA service for the devices, as the PA versions are obsolete. If you are using those devices, enable them. You could also turn on strict mode, and turn your distance slider to 1000km and your Ping Assist slider to 0. This will ensure that you only connect to hosts within the radius. On Congestion Control, you should reset the device prioritisation, and turn on hyper traffic for your console. Overall though, it appears that the Netduma is doing it's job, as your average ping being 31ms is very good; you shouldn't be getting rubber banding or frame drops with such a good ping. Hyper Traffic has been enabled for my device but it was not noted on the screen shot I reset distribution and all devices show equal amounts. I had previously assigned extra Bandwidth to my PC for streaming and uploading.
Netduma Staff Netduma Jack Posted June 23, 2016 Netduma Staff Posted June 23, 2016 Are you still experiencing problems, and have you followed those steps? As stated, your ping is pretty good, and should only cause the problems you've stated if it spikes over 60ms.
A7Legit Posted June 23, 2016 Posted June 23, 2016 Update your firmware, what version are you on currently? You shouldn't have Xbox Live PA or PlayStation Network PA as a service anymore, they were used with older firmware versions. Also after the necessary update(s), look into using Bleeding edge for the cloud in Settings > Miscellenous.
