RedBull2k Posted May 18, 2016 Posted May 18, 2016 I had problems with Congestion Control using PPPoE, and also while using the Netduma behind a router with DMZ it give me throughput issues, but Congestion Control worked, so i needed to find an alternative. I have a Plusnet connection so anyone with the same connection method this will work for if you have a STATIC ip assigned to you. I am not sure how to make it work if you have a dynamic ip. Log onto your HG612 Goto Basic>WAN Select ptm.101 from list under WAN connection Un-check Port binding: LAN1 and LAN2 Connection mode: Route Connection type: PPPoE User name and password to be filled in with your credentials DHCP spoofing: enabled Submit Goto Basic>Lan Lan host settings [the ip address will be your external ip except for last octate] [example your(WAN ip is 84.122.313.23) change to 84.122.313.1 ] ip address: 84.122.313.1 subnet mask 255.255.255.0 click submit DHCP Server check enable primary dns 8.8.8.8 secondary 8.8.4.4 WAN-side address allocation mode: Passthrough associated connection ptm1.101 Submit Log onto Netduma Goto settings LAN change Host address to 192.168.1.1 enable DHCP automatic DNS: Enabled Apply Goto settings WAN WAN ip Enabled ip address: 84.122.313.23 subnet mask 255.255.255.0 gateway ip: 84.122.313.1 primary DNS 8.8.8.8 secondary DNS: 8.8.4.4 Apply With this setup you dont need to use DMZ, you can use the Netduma for UPnP, PortForwarding and LAN The PPPoE on the netduma is not the best for Congestion Control atleast for me. edit To log back into your modem use your new gateway ip address example 84.122.313.1 you do not need to use LAN2 on modem for access
Administrators Netduma Fraser Posted May 19, 2016 Administrators Posted May 19, 2016 Great to hear you found a solution for your issue and thanks for posting up what you did!
Myst1caL Posted May 23, 2016 Posted May 23, 2016 Nice work been looking to get this setup for a while. I managed to get my Wan IP from the wan status page on the hg612 after entering my pppoe details and just followed the guide after that. Thanks man
RedBull2k Posted May 23, 2016 Author Posted May 23, 2016 if you do not have a static ip you will have to change settings in modem when your ip renews, i believe there is a more permanent way for dynamic ip but i dont know how sorry.
Myst1caL Posted June 16, 2016 Posted June 16, 2016 Just like to say I managed to get my hg612 working with the dynamic IP. I took screenshots of everything so if anyone needs it just ask.
SCambient Posted August 20, 2016 Posted August 20, 2016 Hi Myst1caL if you still have the screenshots could you please post them. Looking to do this myself but have a dynamic ip and want to get it right. Many thanks
