_stevenmilligan Posted March 23, 2016 Posted March 23, 2016 I have the worst internet speeds in the world. This is due to me living in the country side where only Standard BT internet is available. Due to this being the only internet available I had to purchase a Netduma (Helped alot). With this internet I am only dedicated 1Mb of Internet to my house for 12 devices to share which is horrible, everyone can use it but I have this problem where I can use my laptop, phone, ps4 at the same time but as soon as someone starts watching a Youtube video or Stream then on the Network Monitor it is telling me they are using 5 Mb which is a problem. Due to us only having 1 Mb then we cannot do anything once this program is being streamed. Hence everyone else being helpless with 0 bandwidth. My Question. How can I use the devices and have this person watch the stream without them using all the Bandwidth? Yours, Steven
Zennon Posted March 23, 2016 Posted March 23, 2016 Are you using the congestion control? With such low bandwidth you could experiment with higher percentages say 90%
_stevenmilligan Posted March 23, 2016 Author Posted March 23, 2016 Are you using the congestion control? With such low bandwidth you could experiment with higher percentages say 90% Yes I am using Congestion Control. Doesnt matter what Percentage I put it to it still uses majority of it.
Israeli Falafel Posted March 23, 2016 Posted March 23, 2016 you don't have enough bandwidth for anything. That's the truth.
Administrators Netduma Fraser Posted March 23, 2016 Administrators Posted March 23, 2016 How do you have your device prioritisation setup? Is share excess on?
thegaurdian1 Posted March 23, 2016 Posted March 23, 2016 I already messaged you FRASER personally but thought it'd be helpful to post here as well. My internet speeds from my provider are expect to be 150mbps of download and 10mbps of upload. I have the latest 1.03.6g running on my NetDuma R1 router. My R1 router used to work amazing with the settings that are below: Enable deep packet processing. UNCHECKED Allow auto feedback(no personal data ever) to help improve the R1. CHECKED Allow remote access to Netduma tech support. CHECKED Enable upnp forwarding. CHECKED Enable multicast snooping. UNCHECKED Enable link-local IPv6. UNCHECKED Access control panel from WAN(not recommend). UNCHECKED Enable cookies. CHECKED Enable wifi work-around. UNCHECKED Stealth Mode. UNCHECKED Turbo mode. CHECKED Super Turbo mode (disables CC). UNCHECKED Recently though my R1 has been acting up with extremely slow speeds with those settings that worked amazing well in the past. Now i barely get 20 or so of download speed and that is with Deep Packet enabled or it doesn't work almost at all. I've done reset on the R1 and restart on the R1 and Modem with not much success. I apologize in advance for any confusion in posts or anything in regards to this issue. Thank You Asim
thegaurdian1 Posted March 23, 2016 Posted March 23, 2016 I just unchecked the DEEP PACKET and i get speeds of 80mbps of download and 8.12mbps of upload which is amazing for me wired. I hope that the NetDuma R1 will function properly with DEEP PACKET unchecked. I will keep you guys posted.
thegaurdian1 Posted March 23, 2016 Posted March 23, 2016 It all appears to be back to normal. I'll be back in a few hours and check again.
_stevenmilligan Posted March 24, 2016 Author Posted March 24, 2016 Can an admin or moderator give me the best congestion control settings for such a low bandwidth. I want to play COD but the lag is surreal.
Administrators Netduma Fraser Posted March 24, 2016 Administrators Posted March 24, 2016 It all appears to be back to normal. I'll be back in a few hours and check again. Great to hear that. Keep us updated Can an admin or moderator give me the best congestion control settings for such a low bandwidth. I want to play COD but the lag is surreal. How do you have your device prioritisation setup? Is share excess on? Can you answer this please
_stevenmilligan Posted March 25, 2016 Author Posted March 25, 2016 How do you have your device prioritisation setup? Is share excess on? I have it setup that my playstation when I am gaming gets majority. I have share excess on. I also feel that the Hyper Service doesnt really affect my gaming, It should give me first priority but doesnt. I load the profile to the game I am playing, this seem to help. So FIFA or COD.
Administrators Netduma Fraser Posted March 25, 2016 Administrators Posted March 25, 2016 Reset the distribution & apply. Leave share excess on. Why don't you think Hyper-Traffic isn't giving your console priority? It will be sending/receiving before anything else. The profiles are great
