plumbit Posted March 21, 2016 Author Posted March 21, 2016 Yes I have, as this is part of the setup tutorial for the R1. I will get those screen shots to you once I have a chance.
plumbit Posted March 22, 2016 Author Posted March 22, 2016 Hi Zennon as requested please see attached. 9 times out of 10 my opponents are coming from the same state as shown in the second attachment. Please advise me what to do. Thank you.
Administrators Netduma Fraser Posted March 22, 2016 Administrators Posted March 22, 2016 You may be experiencing anti-cheat. Did you have the Geo/strict off then put it on and try to connect? Did you wait 2 mins for the map to clear?
plumbit Posted March 23, 2016 Author Posted March 23, 2016 Hi Netduma Fraser, Over the week end that had just past, I was connecting to opponents outside of my geo filter 9 times out of 10 and they were all coming from the same state as shown in the second attachment above. Sometimes I would connect to them when ping assist was on 0 or on 35, and when connecting through ping assist it "wasn't" always showing a nuke symbol. So basically 3 days straight the identical thing was happening connecting to opponents from that state and the ps4 was not on 24/7. I would turn it off for hours. I also rebooted the R1 many times And even tried the factory reset twice and the same thing was still happening. When I would find an opponent from my state and that's after searching for hours the games speed was fair but when I was getting connected to opponents out of my geo I could not put a finger on them it was so unfair and that is a understatement. Please guide me on how to fix this problem as I need the problem resolved.
Zennon Posted March 23, 2016 Posted March 23, 2016 Are you waiting 2 minutes after making a change as Fraser asks? Also in the service you have the PlayStation change it to anything else so a pc and using the dota service then change it back to your console on the psn. To rule out a bugged out service
Administrators Netduma Fraser Posted March 23, 2016 Administrators Posted March 23, 2016 Can you try the above suggestions from Zennon please. If that doesn't work please post in the request 1 on 1 section after reading the pinned thread.
plumbit Posted March 23, 2016 Author Posted March 23, 2016 Can you please expand your suggestion Zennor? As I did not quite understand what you want me to try.
plumbit Posted March 23, 2016 Author Posted March 23, 2016 Did not understand "so a pc and using the dota service"...
Zennon Posted March 23, 2016 Posted March 23, 2016 Change the service from your console to anything at all then back to the console to make sure the service has not bugged. They were just a suggestion to change to, anything will do.
