Seth_18 Posted March 14, 2016 Posted March 14, 2016 Hi my xbox one has been under strict nat type in the settings and my call of duty has been moderate or strict. can someone explain how i open ports for my netduma to get better power to my xbox and call of duty its been getting really annoying and i just need some help??? anyone
secretface Posted March 14, 2016 Posted March 14, 2016 is your netduma your only router or is it behind another router? Have you tried unchecking UPNP and then click apply and then rechecking upnp and restart xbone?
Administrators Netduma Fraser Posted March 15, 2016 Administrators Posted March 15, 2016 Hi Seth, I believe you have another thread that goes into this issue that has been replied to.
Zennon Posted March 15, 2016 Posted March 15, 2016 is your netduma your only router or is it behind another router? Have you tried unchecking UPNP and then click apply and then rechecking upnp and restart xbone? Great suggestion. If I ever need to get an open NAT and it is always when my first router is rebooted and my duma is not, I uncheck UPnP then re check press the xbox home button start up another game (for a second) then quickly start cod back up and I get an open NAT no need to reboot the xbox
Alex49H Posted March 15, 2016 Posted March 15, 2016 Great suggestion. If I ever need to get an open NAT and it is always when my first router is rebooted and my duma is not, I uncheck UPnP then re check press the xbox home button start up another game (for a second) then quickly start cod back up and I get an open NAT no need to reboot the xbox Yep that works for me too.
