NetriX Posted February 24, 2016 Posted February 24, 2016 I've had this issue since I first received my device on 1.03.4. Is this a common issue? My biggest fear is that if network monitor problems are rendered incorrectly, it could also result in congestion control being mishandled as well - though I believe this not to be the case. Either way, its a simple bug. My bandwidth is 65 Mbps down and 4 up - nowhere near 4.4 Gbit, although I wish. Thanks.
Zennon Posted February 24, 2016 Posted February 24, 2016 I would suggest upgrading, by making a post in this thread http://forum.netduma.com/topic/11018-major-netduma-upgrade-now-available-v-1036/ Please read it carefully. Post leaving the FW number you are on and ticking remote support in misc settings of the Netduma. Fraser will make a post in that thread when it is safe for you to upgrade.
NetriX Posted February 24, 2016 Author Posted February 24, 2016 I'm on the current version 1.03.6, just stated its been a recurring problem since I first received my device and it was running 1.03.4. Thanks.
Dillinger Posted February 24, 2016 Posted February 24, 2016 Scratch that - Just noticed it was upload and download.....
Netduma Staff Netduma Crossy Posted February 24, 2016 Netduma Staff Posted February 24, 2016 Did you change tab and come back onto it?
Administrators Netduma Fraser Posted February 25, 2016 Administrators Posted February 25, 2016 Can you click on the peak so the pie chart appears. What does it say is using that?
