geo filter problems?????????
daz
is anyone else finding it difficult to get a game with it enabled? ive not changed any settings but seems to be hard to find a game now no matter what time of day, im on xbox one so its not an issue to do with some having map packs and some not
Pretty sure it's just a bug , but I'm also experiencing the same problems.
Also take into consideration , tons of people would have quit because of the constant sweaty lobbies
Keep us updated on once those issues have gone if you're still having the same problem
im getting games with the filter disabled easier than with it on but its clearly not a prob with the duma its just that the geo filter amplifies it
call of duty site says servers are working fine but clearly not
