Problems Getting It Right
Hi,
When I first received my Netduma games played perfect but over the last few weeks everything has gone.
I am not sure if I have updated a setting and messed it up or there are genuine issues on BLOPS3.
The latest firmware is installed which is shown in the footer of the admin of the netduma. Question: If I factory reset does that remove the firmware?
I have followed the fine tuning guide without success, http://wiki.netduma.com/doku.php?id=fine_tune_netduma
Would it be possible to have a 1&1 to get me back up and running like it was when I received my Netduma?
Thanks in advance for reading!
Regards
Alex
There are a lot of changes going on in Black Ops 3 right now with Activision/Treyarch adding new content and capabilities.  Hotfixes are going out to many aspects and matchmaking as well. If you haven't changed anything I would have to say this issue may be on their end.  Sometimes the games are hit or miss and it is very difficult trying to find the sweet spot with all these changes happening.  It will get better.
If you were to factory reset it will maintain your current firmware.
Someone will be along to let you know how to set up a one on one.
Hi Buck,
Thank you for your response, i did mess with some settings but i cant find the correct set :(
I will look forward to a dev responding, thank you again :)
Alex
As Buck stated lots of changes going on with the game at the moment,and with changes and variables come a new set of settings to find your "sweet spot" again.
Finding it very hard now to find any games! Taking over a minute to search and when i get into a game it is poor!
I was informed PPPoE may not work with PA, so i searched the Wiki to find a deal link:
http://wiki.netduma.com/doku.php?id=plug_into_an_existing_router
Anyone have a link that works on how to connect my Netgear router to the netduma?
Regards
Can you show the page which links to that link :)
And to connect Modem >> Netgear >> Netduma just connect your Netgear to your modem, put it in bridge mode if possible (if not it does't matter) then connect the Netgear to the Netduma (using port 1 on then Duma). If bride mode isn't available on the Netgear, make sure you turn the Wiif off and have all devices connected to the Duma.
Hey Alex :)
Yeah you should DMZ the Netduma if there is no bridge mode :) I don't think AP mode is the same  - I think that would be for if you are just using the Wifi on the Netgear.
Hi,
Ok not done this before, could you see if that link could get fixed please?
Struggling to get my router sorted.
Alex
Hi,
Alex
An article hasn't been written for that link - that's why it shows as red on the previous page :)
Ok cool, any tutorials around on how to add your own router ? :P
If you're putting the Netgear in-front of the Netduma then it is very easy. Just plug Netgear into modem. Then Netduma into Netgear. Then put the Netduma in the Netter's DMZ. Instructions for DMZ are here.
Ok I will give this a go when i get out of this studio.
Crossy I cant thank you enough for your help :)
I will report back laters :)
OK i have done the setup but now i get no hosting showing up on the map! Any ideas gents?
Is the console definitely connected to the Duma - the Wiif on it hasn't automatically connected to the Netgear or anything?
Ok its showing in device manager as domant :(
EDIT: i take it i put the ethernet cable for the xbox into the netduma. Silly me!
Ok it is now working, now im connecting to the USA server with strict mode on!
Follow this guide if you're connecting to games outside of your GeoFilter.
