Keep connecting outside of Geo filter
That's why then. That update fixes the connecting outside of GeoFilter problem. I think if you looked at how many people downloaded it and who many people are having problems it isn't as many as you'd think :)
I must be honest crossy mate, although the majority of my games have been within my specified radius, when I'm party leader with a few friends it's gone outside the filter.. Once or twice by myself aswel.. I know it sounds ridiculous (set geo 300m and got into a game 321m away) but.. Outside is outside.. This is post update.. Any suggestions?
I am sure you are, but are you remembering to wait 2 minutes before trying to get on another server or is it already still set. Only a thought not saying you arnt or owt just trying to help.
For  those who have updated the FW.
Did you follow the update guide and re add the service as the PA versions do not exists you must select again from the list this time you will see no PA at the end of the description.
  • Have you hard refreshed the GeoFilter page and re-added the service to remove the PA version? It should look like this:
  • The GeoFilter is enabled (button should say 'Disable').
  • Strict mode is ticked.
  • PA is off.
  • Host is not within the actual GeoFilter.
  • You've waited 2 mins without connecting to anything since making these changes.
If you have done the above then you shouldn't connect to anything outside of your GeoFilter.
I did the update and have yet to get a host outside of the Geofilter . It works.
I have tried all of that and i am still connecting outside of my geo filter.I will get a lot of the Yellow triangles with ! or I will get into a full lobby and there wont be anybody on my host filter map
