fttc connection with the R1
i cant see anything to disable the geofilter other than disable where iv set up the psn
  • Replies 182
Guest Netduma_Iain
Yup can you do that, so click the disable button under PSN. Then restart the console & see if your NAT is open.
but it still wont let me set up a dmz it just says dmz server is not on the lan subnet
and does knocking the geofilter off mean i ant block all of europe now ? :-(
Guest Netduma_Iain
Type 2 is an open NAT on playstation, that means your setup is correct.
The Geo-Filter can sometimes block the NAT server meaning it reports you have a closed NAT but you actually have an open NAT. Long story short, your setup is correct :)
now all iv got to do is work out why my plusnet is saying i cant set the ps4 in the dmz ffs
Guest Netduma Fraser
Can you take a screenshot of your plusnet dmz settings please and a screenshot of the device manager on the R1 :)
Guest Netduma_Iain
Mike, you don't need to do anything, if your playstation report it has Type-2, then there is nothing to change :)
but the games are saying the game nat is moderate and this is causing more lag than i had before its made aw unplayable now as there is now 3 x the lag theres also chat connection issues due to my nat setting being set to moderate wheres as before the game reported the nat as open
Guest Netduma_Iain
Hi Mike,
I'm actually developing atm, so I'll let Fraser handle this. But you're mixing a few issues here. Firstly if you disable your geo-filter and get into the game does it say your NAT is open? If so I suggest Fraser guide you through the steps to help with lag. The first being actually getting your in game ping.
Cheers
the game (aw) reports the nat is moderate it has changed from open on the plusnet router to moderate on the r1
Is that after disabling the Geo-filter on the R1?
yup thats geo disabled the geo was enabled before and the game nat was moderate
What was the WAN IP in the device manager on the R1 and what IP did you put into the plusnet for dmz?
If theyre the same can you try this instead please, go to “Settings > Port Forwarding” on the Netduma router and delete all entries. Then go to “Settings > UPnP” and make sure it is enabled.
the r1 says the ps4 ip is 192.168.88.144
this was put into the dmz in the plusnet router and i get told that :-
been there tried that
the bottom bit where it says wan ip i havnt got that
but i have checked the ps4 and i know the ip number that its using
Okay can you upgrade please by following these instructions very carefully http://wiki.netduma.com/doku.php?id=manual_updateafter youve upgraded youll be able to see the WAN IP in the device manager :)
right upgraded (i looked before and it said the router had upto date firmware btw *sighs*) and its showing me a wan of 192.168.1.2 but having looked on the ps4 that says its connecting via 192.168.8.144 ??
Okay fantastic, but the WAN IP 192.168.1.2 in the plusnet DMZ. You need to use the WAN IP not the IP from the PS4.
success its open and im really starting to hate computers i thought keepin all my ripping s/ware upto date etc was a pain but thats a doddle compaired with this malarky i dont know how you do it lol
is there anything else i need to do ?
btw if we can get this working ill have a big R1 on my calling card just to wind them up as i know theres been some grumblings around the net lmfao
