Guest Netduma_Iain Posted February 12, 2015 Posted February 12, 2015 Ok its either the wire or the desktop that is the problem. On the desktop please follow the XP instructions in this thread: http://forum.netduma.com/topic/542-solution-cant-get-to-netduma-dashboard-netduma-bricked/ Can you then see 192.168.88.1 ?
mike Posted February 12, 2015 Author Posted February 12, 2015 i looked at that and couldnt find the settings box anywhere on the pc
mike Posted February 12, 2015 Author Posted February 12, 2015 i have no network and sharing center on my desktop i listed what i have earllier in the thread and having looked through them theres no box/option to change anything
Guest Netduma_Iain Posted February 12, 2015 Posted February 12, 2015 Please follow this instead from step 5 : http://portforward.com/networking/static-xp.htm At Step 9 ignore what it says and choose Obtain IP address automatically Obtain DNS address automatically Thanks
mike Posted February 12, 2015 Author Posted February 12, 2015 found it in the end and followed the info and nope it just times out
Guest Netduma_Iain Posted February 12, 2015 Posted February 12, 2015 Ok how many network adapters did you see when you followed the last instructions. Can you run cmd like yesterday with "ipconfig" on the desktop. What does it say?
mike Posted February 12, 2015 Author Posted February 12, 2015 i saw exactly what it shows on the portforwards page
mike Posted February 12, 2015 Author Posted February 12, 2015 im connected to the plusnet and it shows 192.168.1.150 255.255.255.0 192.168.1.254
mike Posted February 12, 2015 Author Posted February 12, 2015 apart from at the top mine shows connect using NVIDIA nForce 10/100/1000 Mbps
Guest Netduma_Iain Posted February 12, 2015 Posted February 12, 2015 I mean what does ipconfig show on the Desktop buddy
mike Posted February 12, 2015 Author Posted February 12, 2015 192.168.1.150 255.255.255.0 192.168.1.254
Guest Netduma_Iain Posted February 12, 2015 Posted February 12, 2015 Mike I'm 100% sure you are connected to the wrong router.
mike Posted February 12, 2015 Author Posted February 12, 2015 connected to the R1 ran ip config and it shows :- 192.168.88.180 255.255.255.0 192.168.88.1
Guest Netduma_Iain Posted February 12, 2015 Posted February 12, 2015 ok can you access 192.168.88.1 now?
mike Posted February 12, 2015 Author Posted February 12, 2015 waaaaaaaaaaaaaaaayyyyyyyyyyyyyyyhaaaaaaaaaaaaaaaaaaaaaaaaayyyyyyyyyy im in iv left the desktop plugged into it an im on the lappy now soon as the little baloon popped up saying little or no connection i knew summat had changed
Guest Netduma Fraser Posted February 12, 2015 Posted February 12, 2015 waaaaaaaaaaaaaaaayyyyyyyyyyyyyyyhaaaaaaaaaaaaaaaaaaaaaaaaayyyyyyyyyy im in iv left the desktop plugged into it an im on the lappy now soon as the little baloon popped up saying little or no connection i knew summat had changed Yay! Fantastic news, so have you got internet access now?
mike Posted February 12, 2015 Author Posted February 12, 2015 right do i remove the plusnet one in line and connect the r1 to that or remove the plusnet one
Guest Netduma Fraser Posted February 12, 2015 Posted February 12, 2015 right do i remove the plusnet one in line and connect the r1 to that or remove the plusnet one If you have internet access leave everything as it is
mike Posted February 12, 2015 Author Posted February 12, 2015 not tryed yet incase there was summat else i had to do ill go and remove the plusnet now and plug everything into the r1 and see what happens
Guest Netduma Fraser Posted February 12, 2015 Posted February 12, 2015 not tryed yet incase there was summat else i had to do ill go and remove the plusnet now and plug everything into the r1 and see what happens No dont do that, check if you have internet access first
Guest Netduma Fraser Posted February 12, 2015 Posted February 12, 2015 yup i have tinterweb access Connect the rest of your wired devices into the back of the R1 or connect them to the R1 WiFi
mike Posted February 12, 2015 Author Posted February 12, 2015 soon as i take the plusnet router out and plug everything into the R1 i loose internet
