Mdbaxte Posted November 5, 2015 Posted November 5, 2015 I've noticed the wifi will occasionally disconnect all devices connected, any idea what could cause this?
Administrators Netduma Fraser Posted November 6, 2015 Administrators Posted November 6, 2015 Un check wifi workaround in settings > miscellaneous and that should resolve the issue
Mdbaxte Posted November 6, 2015 Author Posted November 6, 2015 I don't see that in my settings>miscellaneous.
PharmDawgg Posted November 6, 2015 Posted November 6, 2015 Are you on the most recent update? At the bottom of the host filtering it should tell you what firmware you are on. Current firmware is 1.03.4 Do not trust the Upgrade selection it might say you are already up to date but you are not. Upgrade you router from here but follow the instructions exactly. Thanks. http://wiki.netduma.com/doku.php?id=manual_update
Mdbaxte Posted November 6, 2015 Author Posted November 6, 2015 Ahhhh...it says I'm running the latest version but I guess I'm not. Thanks.
PharmDawgg Posted November 6, 2015 Posted November 6, 2015 Yeah they haven't implemented that upgrade function yet. I think it was causing some issues with the router.
fuzzy clam Posted November 6, 2015 Posted November 6, 2015 Agreed Buck lots of people think their running the most current firmware but they are not. We should have a post somewhere easy to spot (sticky) and have the most current firmware on it and update in as the new stuff comes out.
Administrators Netduma Fraser Posted November 6, 2015 Administrators Posted November 6, 2015 If you look at the wiki sub forum above general support it does say that, I guess no one reads it lol
fuzzy clam Posted November 7, 2015 Posted November 7, 2015 Yeah I was thinking somewhere easier to spot so people would almost be forced to see it when they sign in. I know it already posted but like you said must be people aren't reading it,just thinking out loud.
Netduma Staff Netduma Crossy Posted November 7, 2015 Netduma Staff Posted November 7, 2015 Yeah I was thinking somewhere easier to spot so people would almost be forced to see it when they sign in. I know it already posted but like you said must be people aren't reading it,just thinking out loud. It is also PMd to new members, lol.
fuzzy clam Posted November 7, 2015 Posted November 7, 2015 It is also PMd to new members, lol. Well damn man I guess people need to start paying attention then huh...
