bxdied Posted October 25, 2015 Posted October 25, 2015 Before my Netduma, I had a 50/50, now, all I can get is a 50/20 at the most, i need this to either get fixed asap or I will be returning
zombitroid Posted October 25, 2015 Posted October 25, 2015 what are your congestion sliders set at? also check the network monitor and see which devices are taking up the 60% if there are any. also, does your old router still give you those speeds? and check all the ethernet cords and cables that are used in your house to connect to the internet. also, check and see what your congestion control flower look like. if your ps4 has 80% upload bandwidth and its on then your pc is going to get significantly lower upload speeds.... let us know how its going, we are here to help. we will get this solved in no time if the problem is with the duma.
Zennon Posted October 25, 2015 Posted October 25, 2015 Why are my speeds lower Fine tune the Netduma Device prioritisation , share excess ticked , press reset and press updated distribution.
fuzzy clam Posted October 25, 2015 Posted October 25, 2015 Before my Netduma, I had a 50/50, now, all I can get is a 50/20 at the most, i need this to either get fixed asap or I will be returning Slow down and take it easy.No reason to come on the forum demanding things to get fixed asap or your gonna return the product. It sends the wrong message to everyone right off the bat,sorry to hear your having issues with your speeds.I'm sure if follow the instructions on the links Z posted,it will be fine. If not come back to the forum and make another post about your situation and we'll get it sorted out for you.This site has tons of really smart people all willing to help fix any issues that arise with the duma.So no need to be so brash with your first post. Keep us updated
Administrators Netduma Fraser Posted October 25, 2015 Administrators Posted October 25, 2015 Let us know how you get on with the links provided
bxdied Posted October 26, 2015 Author Posted October 26, 2015 Why are my speeds lower Fine tune the Netduma Device prioritisation , share excess ticked , press reset and press updated distribution. did, still same speeds
bxdied Posted October 26, 2015 Author Posted October 26, 2015 what are your congestion sliders set at? also check the network monitor and see which devices are taking up the 60% if there are any. also, does your old router still give you those speeds? and check all the ethernet cords and cables that are used in your house to connect to the internet. also, check and see what your congestion control flower look like. if your ps4 has 80% upload bandwidth and its on then your pc is going to get significantly lower upload speeds.... let us know how its going, we are here to help. we will get this solved in no time if the problem is with the duma. currently everything is on same percentage and sliders are at 100 and getting 50/20
Zennon Posted October 26, 2015 Posted October 26, 2015 Have you set up the Congestion control? Have you tried an different Ethernet cable?
Administrators Netduma Fraser Posted October 26, 2015 Administrators Posted October 26, 2015 Make sure to reset device prioritisation as well just before doing a test
bxdied Posted October 28, 2015 Author Posted October 28, 2015 Make sure to reset device prioritisation as well just before doing a test i did its still the same
Administrators Netduma Fraser Posted October 29, 2015 Administrators Posted October 29, 2015 i did its still the same Did you try what Zennon says in the comment above mine?
