Modesty Posted October 18, 2015 Posted October 18, 2015 I play cod aw on the ps4 and I'm having trouble connecting to parties and custom games. I have reset my router and modem like 20x. Still hasn't fixed the problem. What should I do?
Yam Yam Posted October 18, 2015 Posted October 18, 2015 Can't you see your friend/s on the geo-filter map ? Â Invite one friend to your cod party or a PS/XBone headset party, they will appear on the world map as a large circle. Click it & rate them at 100% on the Allow list and now do the same thing for all other friends. You will have to enlarge the geo filter also as to combat matchmaking in further regions. Â You will have problems if any one of your friends Nat is Moderate or Strict.
PharmDawgg Posted October 18, 2015 Posted October 18, 2015 Welcom the forum Modesty, if these are friends you are partying up with you may need to add them to your allow list and that way the R1 won't stop you from connecting to them. Â Here are some instructions on how to do this:Â http://wiki.netduma.com/doku.php?id=adding_friends_to_your_allow_list
Administrators Netduma Fraser Posted October 19, 2015 Administrators Posted October 19, 2015 Also just to add have strict mode off as this will help
