KAC1023 Posted October 7, 2015 Posted October 7, 2015 I tried something silly, felt like it worked in the last 6 games, after each game I left the lobby and rejoined for consistency. Give this a shot people. 1.Assuming you followed NetDumas instructions all the way though for assigning a IP to your console, setting your geo filter, congestion control, etc. Keep all that the way they want you to. 2.Go to "Device manager" and take note of the last 3 #'s of the console you want to use's IP address, mine is 111... 3.Go to "Settings/Port Forwarding". a.For "Rule name" I put PSN (because I play on PS4), you can put XBlive for X1. b.For "Start Port" and "End Port" but 3074, this port is used on both Xbox and PS for "gaming" c.For "protocol" drag it open to use BOTH UDP&TCP d.For "IP Address" enter your consoles last 3 #'s for it's assigned IP. e.Click "Add Rule", Click "Apply" 4.Go to "Settings/UPnP" and untic "enable" UPnP. 5.Fire up your console and let me know how your game is.
Chive972 Posted October 7, 2015 Posted October 7, 2015 It's just because the PS4 have a issue with upnp but it's not a problem on Xbox
MadBrad Posted October 7, 2015 Posted October 7, 2015 Every connection after doing this made it way worse, dead round corners etc. UPNP back on and its sweet again, sorry mate, the lag comp still stands
A7Legit Posted October 7, 2015 Posted October 7, 2015 It made no difference for me. When I reverted back and turned on UPNP I found that 3074 only is used for XBL on my end, my PSn doesn't use 3074.
Sir_smooch Posted October 7, 2015 Posted October 7, 2015 I tried something silly, felt like it worked in the last 6 games, after each game I left the lobby and rejoined for consistency. Give this a shot people. 1.Assuming you followed NetDumas instructions all the way though for assigning a IP to your console, setting your geo filter, congestion control, etc. Keep all that the way they want you to. 2.Go to "Device manager" and take note of the last 3 #'s of the console you want to use's IP address, mine is 111... 3.Go to "Settings/Port Forwarding". a.For "Rule name" I put PSN (because I play on PS4), you can put XBlive for X1. b.For "Start Port" and "End Port" but 3074, this port is used on both Xbox and PS for "gaming" c.For "protocol" drag it open to use BOTH UDP&TCP d.For "IP Address" enter your consoles last 3 #'s for it's assigned IP. e.Click "Add Rule", Click "Apply" 4.Go to "Settings/UPnP" and untic "enable" UPnP. 5.Fire up your console and let me know how your game is Could i not just leave upnp and do the other things you said
Administrators Netduma Fraser Posted October 7, 2015 Administrators Posted October 7, 2015 Wouldn't really advise this as UPnP opens more than just that port usually. Could i not just leave upnp and do the other things you said Having UPnP and port forwarding opening the same ports can cause conflicts
Sir_smooch Posted October 7, 2015 Posted October 7, 2015 Wouldn't really advise this as UPnP opens more than just that port usually. Having UPnP and port forwarding opening the same ports can cause conflicts Oh ok...... scrap that then!!! Noob in the room ****Points to self
Chive972 Posted October 7, 2015 Posted October 7, 2015 Port forwarding works perfect on PS4 but not with the Xbox. You can't put port forwardind and UPNP at the same time: they both open ports but one is manual and the other is automatic.
A7Legit Posted October 7, 2015 Posted October 7, 2015 During the BO3 beta I don't recall disabling UPNP and I had many ports forwarded to get an OPEN NAT for both the PS4 and XB1. The one that made the difference for the BO3 beta was actualy 3075.
Administrators Netduma Fraser Posted October 7, 2015 Administrators Posted October 7, 2015 During the BO3 beta I don't recall disabling UPNP and I had many ports forwarded to get an OPEN NAT for both the PS4 and XB1. The one that made the difference for the BO3 beta was actualy 3075. It's fine if you're opening different ports but if opening the same ones its generally not a good idea
KAC1023 Posted October 7, 2015 Author Posted October 7, 2015 OK, sorry for late reply. I'm sure everyone is different with their setups, some have router/modems, some have other routers before and after their Dumas. I have Verizon FIOs, before the Duma I used to "check" on my port forwarding that UPnP opened for me when I had Xbox 360 (Modern Warfare 2 days), sometimes my connection would be jumpy (still having 4 bars). When I checked port forwarding it showed 3074 TCP when it should be UDP.. Once I changed it the game was dead on. Even with AW I will go into the online menu and disable UPnP so 3074UDP is "closed" and the game is more dead on, but I feel like shots are missing. I don't know guys, just trying to find the best way to get this game to work the best, in America we have a term "throwing sh*& at a wall and seeing what sticks", and I guess my idea didn't "stick" for some people. I also tried cutting bandwidth, didn't work. Settings device prioritization to 1% and not sharing excess, didn't work Sorry guys, gonna hop on now (5pm EST) and see what kinda connection I get. But I would like to thank the few that tried my "idea" and see if it worked for them.
Administrators Netduma Fraser Posted October 8, 2015 Administrators Posted October 8, 2015 Yeah totally understand that, its about finding what works best for you at the end of the day. I don't really believe in lag comp per se but if you need any help let me know
