I have your netduma router. It use to work just fine. I stopped gaming and disconnected it. Now I want to re connect it again.
I have it wired from the modem to the netduma, "I don't want to use wireless from the netduma"
I then have it wired to my nighthawk netgear router. I forgot how to hook it up and what I have to turn off in the netgear to make this work. Please help.
So you want to use the wireless from the Netduma? It sounds like you might need to put the Nighthawk into AP mode - you can follow the instructions here to do that.
Yes. Thank you bud. I am so retarded when it comes to this stuff. Lol
Haha, no worries :D Did you work out some good settings for Bops2 and MW3?
