BoB Posted September 21, 2015 Posted September 21, 2015 When i go to buy my net duma R1 Router it says complete the order below then when i go below there is nothing there.Can anybody please help.
bagsta69 Posted September 21, 2015 Posted September 21, 2015 Could you post a link to the page please. It maybe your resolution settings that mean you may need to scroll down the page a bit to input your details. https://netduma.com/order/netduma-r1-router/ I just went to this page and all seems fine!!!
Zennon Posted September 21, 2015 Posted September 21, 2015 Or it could be a browser issue, can you try it with a different browser.
Administrators Netduma Fraser Posted September 21, 2015 Administrators Posted September 21, 2015 Hey BoB, I just checked it as well, all seems fine this end, could you try a different device/browser please
BoB Posted September 22, 2015 Author Posted September 22, 2015 Hey guys thanks for the help im on android so i use the normal browser which is just called internet but when i used google chrome it worked thanks again i really appreciate it
Dillinger Posted September 22, 2015 Posted September 22, 2015 Hey guys thanks for the help im on android so i use the normal browser which is just called internet but when i used google chrome it worked thanks again i really appreciate it Welcome to the Duma Community BoB - Once your new router shows up we will be happy to help you get it up and running. Of course then you get drafted into the #DumaArmy, but you know.....
Administrators Netduma Fraser Posted September 23, 2015 Administrators Posted September 23, 2015 Awesome thanks for ordering! As the issue is resolved I'll close the thread, feel free to open another if needed. Welcome to the forum!
