lordkenny Posted August 27, 2015 Posted August 27, 2015 Hello i have just got my netduma and i am following the setup guide for the sky sr102 hub but when i get to where it says to click to open up the netduma GUI it does not load anything can anyone help as i have been trying to sort this out for some hours now thanks all ;-D
lordkenny Posted August 27, 2015 Author Posted August 27, 2015 yes i tried the adress but no good.. my computer shows the netduma r1 device but when i tried to connect to it, it asked for sercurity key stuff?
lukasz Posted August 27, 2015 Posted August 27, 2015 Please could you confir you try this http://wiki.netduma.com/doku.php?id=why_does_the_gui_not_work Then see if thats helps http://wiki.netduma.com/doku.php?id=can_t_connect_to_the_internet_or_access_the_dashboard and finally check this http://wiki.netduma.com/doku.php?id=can_t_access_the_router_home_page
lordkenny Posted August 27, 2015 Author Posted August 27, 2015 ok very sorry about this, i didnt read all the info in front of me. the fix was i had not put on the correct sercurity code to connect to netduma r1 but its on the box so thanks for all the help i will probly be back soon take care ;-D
PharmDawgg Posted August 27, 2015 Posted August 27, 2015 Great lordkenny . Since your issue has been corrected I will lock this post. Please feel free to return when you have any other issues or just to chat. Game on.
