blue water Posted October 12 Posted October 12 Today I updated my netduma r3 router to new firmware to 4.0.1510 I was recently on the beta firmware and after updating my gio filter is not working properly I usually play dead by daylight and I usually will connect to north Virginia servers now when I try to play the netduma is saying I'm connected to a Oklahoma city server but there is no server in Oklahoma my ping is showing like I'm connected to Virginia but the dashboard is showing Oklahoma city makes no sense if a dev could help me out I would truly appreciate it I also want to say that there is no peer to peer in dbd it's dedicated servers only
Administrators Netduma Fraser Posted October 12 Administrators Posted October 12 Is it literally just that it's named Oklahoma instead or Virginia? If so ignore that and we'll fix it in a cloud update if you can provide us the ID of the server
blue water Posted October 12 Author Posted October 12 So basically what is happening is on my netduma dashboard it shows that I'm connected to Oklahoma city and where the server is showing is actually in Oklahoma city usually before the update took place the map would show Norfolk Virginia and where the server was showing on the map was actually in Norfolk Virginia also I have noticed as well when deleting a device for some reason when u hit the button it hangs for a minute then it deletes the device and then when adding a device it hangs as well kinda seems laggy before the update it was more responsive and the server locations displayed correctly and I never connected to Oklahoma city only server I have ever connected to is Norfolk Virginia seems like it's connecting to Norfolk Virginia but showing on my screen on the dashboard that I'm connected to Oklahoma city and the location on the map is actually in Oklahoma city
blue water Posted October 12 Author Posted October 12 Okay so I got the server id and I do apologize it's actually connecting to a state above Oklahoma I misread where the location is I do apologize about the confusion but the ping is still reading like I'm connected to Norfolk Virginia
Administrators Netduma Fraser Posted October 13 Administrators Posted October 13 Okay so it's probably just mislocated on the map, don't worry about it, we'll get it sorted in a cloud update, thanks for the report!
blue water Posted October 13 Author Posted October 13 Your very welcome and thank u and the rest of the dev team for all the hard work y'all put into making the netduma routers possible DARKNESS and Netduma Fraser 1 1
Administrators Netduma Fraser Posted October 14 Administrators Posted October 14 Thanks for the kind words, appreciate it!
