blue water Posted July 12 Posted July 12 When I had my netduma r2 I could install the new firmware from the duma os app can u still upgrade beta firmware from the app it self or do u have to use the browser just curious cause I would think u can still upgrade firmware the same way on the r3 router
DARKNESS Posted July 12 Posted July 12 @blue waterIt’s the same procedure, though it’s always recommended to do it over a wired connection. You just need to make sure you’re not uploading the wrong file, as that could potentially brick the router.
blue water Posted July 12 Author Posted July 12 Thank u so much for helping me with this I truly appreciate it sorry if it was a stupid question I'm just new to the r3 router
Administrators Netduma Fraser Posted July 12 Administrators Posted July 12 Did you manage to upgrade successfully?
blue water Posted July 12 Author Posted July 12 When I uploaded the file it started to upgrade it then told me that it didn't load the file correctly the router then rebooted and then came back on I checked the firmware version and it's the new firmware so idk exactly what happened but the netduma has internet connection and I can access the dashboard
blue water Posted July 12 Author Posted July 12 Okay so after i upgraded the router its still trying to connect to a blocked server and also I don't think ping assist is working properly I would factory reset at this point but if I factory reset I won't be able to get back into the dashboard because when trying to factory reset from a phone it seems to not want to display wifi
blue water Posted July 12 Author Posted July 12 So I did the factory reset and it went really well I thought I wasn't gonna be able to connect to the netduma but I was wrong I was able to connect to it right away and the problem has been fixed no more blocked server popping up and also ping assist is working really well
Administrators Netduma Fraser Posted July 13 Administrators Posted July 13 Good to hear you got it sorted, thanks for the update!
