YamahaX Posted May 14, 2024 Share Posted May 14, 2024 good evening to the team. I am a new netduma r3 owner. Guys, I am really very unhappy with this purchase. it works worse than when I had the original router. One problem is that ipv6 is not working, ms are higher and not stable than they were with originals, I have tried many settings, I have changed firmware from 4.0.21 to 4.0.23 and in 4.0.41 41 is a bit better but also it's already bad. I can't justify a router like that costing 200 euros to work like that the game I play is warzone Link to comment Share on other sites More sharing options...
Administrators Netduma Alex Posted May 14, 2024 Administrators Share Posted May 14, 2024 Hi @YamahaX, I'm sorry to hear that you're not happy with the Netduma R3. I'll try to address your specific issues: 1 hour ago, YamahaX said: One problem is that ipv6 is not working We are aware of issues with IPv6, and we're planning to fix them in an upcoming firmware update. 1 hour ago, YamahaX said: ms are higher and not stable than they were with originals It's possible that the reason they're higher is because of Steady Ping. This feature raises your ping slightly in order to create a buffer which compensates for jitter, meaning you have a smoother gameplay experience. However the fact you say that your ping does not feel stable makes me think this may not be what's causing it. Would you be interested in having early access to an upcoming firmware in order to see if your issues are improved at all? Link to comment Share on other sites More sharing options...
YamahaX Posted May 14, 2024 Author Share Posted May 14, 2024 thank you for your good intention to help immediately this is important. yes I would like to be sent all patched updates before they go live so I can test them, hopefully they will be fixed as soon as possible Link to comment Share on other sites More sharing options...
Nj12 Posted May 14, 2024 Share Posted May 14, 2024 4 hours ago, YamahaX said: good evening to the team. I am a new netduma r3 owner. Guys, I am really very unhappy with this purchase. it works worse than when I had the original router. One problem is that ipv6 is not working, ms are higher and not stable than they were with originals, I have tried many settings, I have changed firmware from 4.0.21 to 4.0.23 and in 4.0.41 41 is a bit better but also it's already bad. I can't justify a router like that costing 200 euros to work like that the game I play is warzone There will be a public firmware released soon, I've been using one of the latest "beta" versions and they have certainly make great improvements. Link to comment Share on other sites More sharing options...
Administrators Netduma Alex Posted May 15, 2024 Administrators Share Posted May 15, 2024 @YamahaXI have added you to the Early Access testers group. You can download the latest firmware here. Link to comment Share on other sites More sharing options...
YamahaX Posted May 15, 2024 Author Share Posted May 15, 2024 @Netduma Alexthank you Link to comment Share on other sites More sharing options...
Evanfly Posted May 15, 2024 Share Posted May 15, 2024 I have only used my R3 for a week & I've gone back to my Xr1000 until the R3 improves,would it be possible to add me for access to the beta please Link to comment Share on other sites More sharing options...
Administrators Netduma Alex Posted May 15, 2024 Administrators Share Posted May 15, 2024 @Evanfly I have added you to the Early Access testers group. You can download the latest firmware here. Evanfly 1 Link to comment Share on other sites More sharing options...
Evanfly Posted May 17, 2024 Share Posted May 17, 2024 @Netduma Alex Thank you Netduma Fraser 1 Link to comment Share on other sites More sharing options...
Stephen1989 Posted May 25, 2024 Share Posted May 25, 2024 Hi guys! I want to order R3. This IPv6 problem is solved with the new early access firmware? Thanks for the answer. ✌🏻 Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted May 25, 2024 Administrators Share Posted May 25, 2024 9 minutes ago, Stephen1989 said: Hi guys! I want to order R3. This IPv6 problem is solved with the new early access firmware? Thanks for the answer. ✌🏻 I can't say for certain but I haven't seen anyone report it Link to comment Share on other sites More sharing options...
YamahaX Posted May 26, 2024 Author Share Posted May 26, 2024 @Netduma Fraser@Stephen1989ipv6 is not fixed yet.i have the v4.0.214 update Stephen1989 1 Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted May 26, 2024 Administrators Share Posted May 26, 2024 2 hours ago, YamahaX said: @Netduma Fraser@Stephen1989ipv6 is not fixed yet.i have the v4.0.214 update What's the issue you're having with it exactly? Link to comment Share on other sites More sharing options...
YamahaX Posted May 26, 2024 Author Share Posted May 26, 2024 @Netduma Fraser Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted May 26, 2024 Administrators Share Posted May 26, 2024 What is the model of the modem/router the R3 is connected to and how have you set that to ensure all traffic flows to the R3? E.g. R3 in its DMZ, modem/bridge mode Is IPv6 enabled in LAN & WAN on the R3? If so disable on LAN, does it work then? Do you get IPv6 directly connected to your modem? Link to comment Share on other sites More sharing options...
YamahaX Posted May 26, 2024 Author Share Posted May 26, 2024 @Netduma FraserI have active dmz on my modem router, I have turned off ipv6 on the lan and still nothing. if I connect the modem router alone, ipv6 works normally, even if I connect another router. Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted May 26, 2024 Administrators Share Posted May 26, 2024 If you put the ISP router in modem/bridge mode instead do you then get IPv6 through the R3? Link to comment Share on other sites More sharing options...
YamahaX Posted May 26, 2024 Author Share Posted May 26, 2024 @Netduma Fraser i have try it too it, has no effect. Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted May 26, 2024 Administrators Share Posted May 26, 2024 Okay thanks for trying, just wanted to make sure we covered all the bases, the team will get it sorted Link to comment Share on other sites More sharing options...
YamahaX Posted May 26, 2024 Author Share Posted May 26, 2024 @Netduma Fraserlet me know any new update thank you. Netduma Fraser 1 Link to comment Share on other sites More sharing options...
