slackchain Posted May 13, 2024 Share Posted May 13, 2024 I have had this router for some time now. I have been on firmware 3.3.280 for about a year. It started dropping wifi connection about 4days ago. Since, I have factory reset the router, re flashed firmware, DHCP is set to max release, tried reserved DHCP, Mirror Wifi, separated wifi SSID, manually tested channels, and disabled 5g tested 2.40 and disabled 2.4 and test 5 g. No matter what it will drop wifi for time periods as long as 10 to 20 minutes. Some times it will drop and I have to unplug the router or reboot. I singed up for early access today. I'm to the point I'm about to warranty the item with Squaretrade. Before I do, I wanted to post here and make sure there is not something Im aware of. Thank you Link to comment Share on other sites More sharing options...
DARKNESS Posted May 13, 2024 Share Posted May 13, 2024 @slackchainDid you try factory resetting from web interface? Link to comment Share on other sites More sharing options...
slackchain Posted May 13, 2024 Author Share Posted May 13, 2024 Just now, DARKNESS said: @slackchainDid you try factory resetting from web interface? I did, I also did a factory reset on the push button after still experiencing issues. Link to comment Share on other sites More sharing options...
Administrators Netduma Alex Posted May 14, 2024 Administrators Share Posted May 14, 2024 Hi @slackchain, When the wifi drops, do devices connected via ethernet remain connected to the internet? Link to comment Share on other sites More sharing options...
slackchain Posted May 24, 2024 Author Share Posted May 24, 2024 Yes, and the 5g stays working most of the time. Link to comment Share on other sites More sharing options...
slackchain Posted May 24, 2024 Author Share Posted May 24, 2024 Darkness, I did and did it from the router button. Sorry for all the delays. Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted May 24, 2024 Administrators Share Posted May 24, 2024 Try: Experiment with the widths Ensure it's in an elevated position - not on a metal surface Ensure there aren't any electrical / wireless devices e.g headphones etc within close proximity ~3 feet if possible Set the antennae to this position _ | | _ Sounds weird but if it's close to a microwave that will cause it to disconnect Link to comment Share on other sites More sharing options...
