docha34 Posted April 14, 2024 Posted April 14, 2024 I ran into this problem eFootball_network_monito > Use npcap api to sniff the udp traffic. Only support wired connection. PS/XBOX players need a router/switch supporting port mirroring. Don't support VPN or proxy. To play eFootball there is such a utility for monitoring the server and workload It is for PC but can be used on Console without any problems You just need to make port forwarding so that the connection from my PS will be broadcast to my PC. I don't understand how to do this on my R3. Very much looking forward to the answer
TrayDay Posted April 14, 2024 Posted April 14, 2024 14 minutes ago, docha34 said: I ran into this problem eFootball_network_monito > Use npcap api to sniff the udp traffic. Only support wired connection. PS/XBOX players need a router/switch supporting port mirroring. Don't support VPN or proxy. To play eFootball there is such a utility for monitoring the server and workload It is for PC but can be used on Console without any problems You just need to make port forwarding so that the connection from my PS will be broadcast to my PC. I don't understand how to do this on my R3. Very much looking forward to the answer No, the R3 does not have port mirroring. You need a "switch" between the R3 and the Console. For example, I have the TP LINK GS105E This allows me to port mirror, my PC and PS5. Both the PC and Console will need to be using/behind the switch. So they can "mirror" each other ports.
TrayDay Posted April 14, 2024 Posted April 14, 2024 Now, you could TRY using your pc as a hotspot. Since it seems like you want to be able to grab the IP. I did this tutorial for capturing wireshark. But, the same principle applies. Just when you get to the end for opening wireshark. Disregard that part. All you want to do is connect your console to the PC's hotspot. Then you can open that efootball PC program you have. Theorectically, it should work. But if not. Then you need a Switch, like I mentioned in the post above. =============================== This is a quick tutorial for Window users. 1. Press Windows Key and type in the word 'hotspot'. You should see "Mobile hotspot". Choose this. 2. In this Mobile Hotspot dialog, you should see an option to Mobile Hotspot 'Enable'. Please enable. You should also see below, 'Share internet connection from' this should be 'Ethernet'. Right below this you should see 'Share over' this should be 'Wi-Fi'. (You can give the name of your Wi-Fi and password in the properties below) 3. I didn't show how to access the network connections in the video. But, you can find the name of your network connection of your Wi-Fi from pressing Windows Key and typing 'network connections' and you click it to open what you see in the video of my Wi-Fi network name on Windows. Mines is "Local Area Connection* 2" with the name from my wifi "Microsoft direct virtual adapter' this is how you know what name of the interface to be looking for in Wireshark as I show the name in Wireshark. 4. Start/Open Wireshark. Click your interface name in Wireshark and begin capturing. Now connect console to hotspot, and you should see it begin to start showing packets Once you have enough captured. You click the red stop or square up top, and you save the capture by the little yellow icon I showed to the right or file>save (or save as) Windows_Wireshark_Capture.mp4.cff76be537453934ae6fcfad03c058d3.mp4
docha34 Posted April 14, 2024 Author Posted April 14, 2024 9 minutes ago, TrayDay said: Now, you could TRY using your pc as a hotspot. Since it seems like you want to be able to grab the IP. I did this tutorial for capturing wireshark. But, the same principle applies. Just when you get to the end for opening wireshark. Disregard that part. All you want to do is connect your console to the PC's hotspot. Then you can open that efootball PC program you have. Theorectically, it should work. But if not. Then you need a Switch, like I mentioned in the post above. =============================== This is a quick tutorial for Window users. 1. Press Windows Key and type in the word 'hotspot'. You should see "Mobile hotspot". Choose this. 2. In this Mobile Hotspot dialog, you should see an option to Mobile Hotspot 'Enable'. Please enable. You should also see below, 'Share internet connection from' this should be 'Ethernet'. Right below this you should see 'Share over' this should be 'Wi-Fi'. (You can give the name of your Wi-Fi and password in the properties below) 3. I didn't show how to access the network connections in the video. But, you can find the name of your network connection of your Wi-Fi from pressing Windows Key and typing 'network connections' and you click it to open what you see in the video of my Wi-Fi network name on Windows. Mines is "Local Area Connection* 2" with the name from my wifi "Microsoft direct virtual adapter' this is how you know what name of the interface to be looking for in Wireshark as I show the name in Wireshark. 4. Start/Open Wireshark. Click your interface name in Wireshark and begin capturing. Now connect console to hotspot, and you should see it begin to start showing packets Once you have enough captured. You click the red stop or square up top, and you save the capture by the little yellow icon I showed to the right or file>save (or save as) Windows_Wireshark_Capture.mp4.cff76be537453934ae6fcfad03c058d3.mp4 95.69 MB · 0 downloads Bro you're freaking awesome) thank you so much you're a big help!!! Thank you so much )())) I already started googling TP Link like you have. Thank you so much. I wish more people like you !!! You are the best
docha34 Posted April 14, 2024 Author Posted April 14, 2024 10 minutes ago, TrayDay said: Now, you could TRY using your pc as a hotspot. Since it seems like you want to be able to grab the IP. I did this tutorial for capturing wireshark. But, the same principle applies. Just when you get to the end for opening wireshark. Disregard that part. All you want to do is connect your console to the PC's hotspot. Then you can open that efootball PC program you have. Theorectically, it should work. But if not. Then you need a Switch, like I mentioned in the post above. =============================== This is a quick tutorial for Window users. 1. Press Windows Key and type in the word 'hotspot'. You should see "Mobile hotspot". Choose this. 2. In this Mobile Hotspot dialog, you should see an option to Mobile Hotspot 'Enable'. Please enable. You should also see below, 'Share internet connection from' this should be 'Ethernet'. Right below this you should see 'Share over' this should be 'Wi-Fi'. (You can give the name of your Wi-Fi and password in the properties below) 3. I didn't show how to access the network connections in the video. But, you can find the name of your network connection of your Wi-Fi from pressing Windows Key and typing 'network connections' and you click it to open what you see in the video of my Wi-Fi network name on Windows. Mines is "Local Area Connection* 2" with the name from my wifi "Microsoft direct virtual adapter' this is how you know what name of the interface to be looking for in Wireshark as I show the name in Wireshark. 4. Start/Open Wireshark. Click your interface name in Wireshark and begin capturing. Now connect console to hotspot, and you should see it begin to start showing packets Once you have enough captured. You click the red stop or square up top, and you save the capture by the little yellow icon I showed to the right or file>save (or save as) Windows_Wireshark_Capture.mp4.cff76be537453934ae6fcfad03c058d3.mp4 95.69 MB · 0 downloads In general, it is very strange that there is no such function in such a router as NetDuma R3.
ChrisG82 Posted April 14, 2024 Posted April 14, 2024 36 minutes ago, docha34 said: In general, it is very strange that there is no such function in such a router as NetDuma R3. Not really. Port mirroring is a function that is needed more in the business sector than in the gaming sector. And as already recommended, if I were you I would simply get a small switch from Netgear, for example, and connect it between R3, PC and PlayStation. The GS105Ev2 would probably be enough...
docha34 Posted April 14, 2024 Author Posted April 14, 2024 21 minutes ago, ChrisG82 said: Not really. Port mirroring is a function that is needed more in the business sector than in the gaming sector. And as already recommended, if I were you I would simply get a small switch from Netgear, for example, and connect it between R3, PC and PlayStation. The GS105Ev2 would probably be enough... If you purchase such a device Does it need to be customized or not?
ChrisG82 Posted April 14, 2024 Posted April 14, 2024 When I buy a gaming router, I expect it to primarily offer gaming features and not business features. Everything else is a bonus.
docha34 Posted April 14, 2024 Author Posted April 14, 2024 3 minutes ago, ChrisG82 said: When I buy a gaming router, I expect it to primarily offer gaming features and not business features. Everything else is a bonus. You misunderstood me. I meant about the port switch. If I buy it. Does it have to be configured or not?
ChrisG82 Posted April 14, 2024 Posted April 14, 2024 Ah, okay. Yes, the switch gets an IP just like any other client. You can use it to access the web interface. Then you have to specify which port should be mirrored. look here: Manual docha34 1
Administrators Netduma Fraser Posted April 14, 2024 Administrators Posted April 14, 2024 Great advice from everyone on this! docha34 1
docha34 Posted April 15, 2024 Author Posted April 15, 2024 On 4/14/2024 at 2:23 AM, ChrisG82 said: Ah, okay. Yes, the switch gets an IP just like any other client. You can use it to access the web interface. Then you have to specify which port should be mirrored. look here: Manual I don't know much about this stuff. Bro, if I buy this model, will it fit?
docha34 Posted April 15, 2024 Author Posted April 15, 2024 On 4/14/2024 at 12:01 AM, TrayDay said: No, the R3 does not have port mirroring. You need a "switch" between the R3 and the Console. For example, I have the TP LINK GS105E This allows me to port mirror, my PC and PS5. Both the PC and Console will need to be using/behind the switch. So they can "mirror" each other ports. I don't know much about this stuff. Bro, if I buy this model, will it fit?
TrayDay Posted April 15, 2024 Posted April 15, 2024 1 hour ago, docha34 said: I don't know much about this stuff. Bro, if I buy this model, will it fit? You need the E version. Manage switch or what TP Link calls their switches that port mirroring and more, their "Easy Smart Switches" or "Smart Switches". I have this version, but it's an E at the end. TL-SG105E.
docha34 Posted April 16, 2024 Author Posted April 16, 2024 6 hours ago, TrayDay said: You need the E version. Manage switch or what TP Link calls their switches that port mirroring and more, their "Easy Smart Switches" or "Smart Switches". I have this version, but it's an E at the end. TL-SG105E. Friend, do you know how to do this on an asus router ? I have an asus router with a mirror image. But I can't find instructions on the internet.
docha34 Posted April 16, 2024 Author Posted April 16, 2024 On 4/14/2024 at 5:25 AM, Netduma Fraser said: Great advice from everyone on this! I have a question I have another router Netgear XR500 if I make it in bridge mode will it work for my purposes? To have one network for PS5 and PC?
Administrators Netduma Fraser Posted April 16, 2024 Administrators Posted April 16, 2024 6 hours ago, docha34 said: I have a question I have another router Netgear XR500 if I make it in bridge mode will it work for my purposes? To have one network for PS5 and PC? It doesn't have a bridge mode but it does have an AP mode. You can then connect that behind the R3 (to one of the LAN ports) and all devices will appear on the R3 as though they are directly connected to it
TrayDay Posted April 16, 2024 Posted April 16, 2024 12 hours ago, docha34 said: Friend, do you know how to do this on an asus router ? I have an asus router with a mirror image. But I can't find instructions on the internet. Port Mirroring is not available on consumer grade routers. You would need to install third party software on the router to access port mirroring. I wouldn't install third party software on your Asus router. As you may, brick your router. The easiest way to do what you want is to use a "switch" like the one I recommended earlier. They are cheap. I don't recommended it. But if you really want to try installing third party software, you can follow along with this video. Someone said, when you get to the command to use -I . Replace -I with -A instead. Again, I don't recommend, but hope this helps.
docha34 Posted April 19, 2024 Author Posted April 19, 2024 On 4/16/2024 at 10:21 AM, TrayDay said: Port Mirroring is not available on consumer grade routers. You would need to install third party software on the router to access port mirroring. I wouldn't install third party software on your Asus router. As you may, brick your router. The easiest way to do what you want is to use a "switch" like the one I recommended earlier. They are cheap. I don't recommended it. But if you really want to try installing third party software, you can follow along with this video. Someone said, when you get to the command to use -I . Replace -I with -A instead. Again, I don't recommend, but hope this helps. Bro you don't understand me( I have an Asus router, it's a gaming router and it has this function but I can't set it up. Please help me.
TrayDay Posted April 19, 2024 Posted April 19, 2024 15 minutes ago, docha34 said: Bro you don't understand me( I have an Asus router, it's a gaming router and it has this function but I can't set it up. Please help me. What's the asus router you have?
docha34 Posted April 19, 2024 Author Posted April 19, 2024 Just now, TrayDay said: What's the asus router you have? DSL-AX82U Firmware:3004.388.6_0-gnuton1
TrayDay Posted April 19, 2024 Posted April 19, 2024 1 hour ago, docha34 said: DSL-AX82U Firmware:3004.388.6_0-gnuton1 There's only an option to WAN mirror. But, there's no option to LAN mirror in the menu. You have to use a command to port mirror. Here's a written guide on how to do that, along with the video I provided earlier with a visual demonstration. https://computermentor.net/guides/guides/asus-port-mirror.php
docha34 Posted April 19, 2024 Author Posted April 19, 2024 5 minutes ago, TrayDay said: Есть только опция WAN mirror. Но в меню нет опции LAN mirror. Для зеркального переноса необходимо использовать команду. Вот письменное руководство о том, как это сделать, а также видео, которое я предоставил ранее с наглядной демонстрацией. https://computermentor.net/guides/guides/asus-port-mirror.php I don't really understand what he's doing in the video? can you elaborate? Please) You are the only person who understands what I need). -iptables -I PREROUTING -t mangle -j ROUTE --gw (Ip-of-your-IDS) --tee. what IP should I specify here ? My PS5 or my pc ?
TrayDay Posted April 19, 2024 Posted April 19, 2024 Try this iptables -t mangle -A PREROUTING -s PS5 IP HERE -j TEE --gateway PC IP HERE iptables -t mangle -A POSTROUTING -d PS5 IP HERE -j TEE --gateway PC IP HERE
docha34 Posted April 19, 2024 Author Posted April 19, 2024 3 minutes ago, TrayDay said: Try this iptables -t mangle -A PREROUTING -s PS5 IP HERE -j TEE --gateway PC IP HERE iptables -t mangle -A POSTROUTING -d PS5 IP HERE -j TEE --gateway PC IP HERE iptables: No chain/target/match by that name. 😪
