kevin88230 Posted February 7, 2024 Share Posted February 7, 2024 Hello, the network speed is not working, do you know why, I restarted the netduma to factory but still the same Link to comment Share on other sites More sharing options...
idvizual Posted February 8, 2024 Share Posted February 8, 2024 Turn off IPV6 LAN and WAN if you haven't yet. Its worked for me when testing on waveform. Link to comment Share on other sites More sharing options...
kevin88230 Posted February 8, 2024 Author Share Posted February 8, 2024 je vais essayer ce soir, Modifications must be made on the netduma or modem Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted February 8, 2024 Administrators Share Posted February 8, 2024 You can try the IPv6 suggestion but we are aware the test isn't always accurate, you can manually change the speeds Link to comment Share on other sites More sharing options...
kevin88230 Posted February 8, 2024 Author Share Posted February 8, 2024 The speeds are already manually set to 100 mbps and 50 mbps but during the test it does not take them into account for me Link to comment Share on other sites More sharing options...
kevin88230 Posted February 8, 2024 Author Share Posted February 8, 2024 If I deactivate netduma's IPv6 I no longer have a connection and I cannot deactivate it on my provider's modem Link to comment Share on other sites More sharing options...
DanologyUK Posted February 8, 2024 Share Posted February 8, 2024 2 hours ago, kevin88230 said: The speeds are already manually set to 100 mbps and 50 mbps but during the test it does not take them into account for me If you set the speeds manually, you dont need to run the test. Link to comment Share on other sites More sharing options...
kevin88230 Posted February 8, 2024 Author Share Posted February 8, 2024 Yes but during the test the speeds recorded manually are not taken into account Link to comment Share on other sites More sharing options...
kevin88230 Posted February 8, 2024 Author Share Posted February 8, 2024 My internet speed is not limited Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted February 8, 2024 Administrators Share Posted February 8, 2024 You don't need to do the test if you're setting the speeds manually Link to comment Share on other sites More sharing options...
kevin88230 Posted February 9, 2024 Author Share Posted February 9, 2024 I'm trying to get an A+ on bufferbload but the stream recorded manually on the netduma is not taken into account during my tests on my xbox Link to comment Share on other sites More sharing options...
Krush Posted February 9, 2024 Share Posted February 9, 2024 Tu es chez quel opérateur ? Tu dois forcément avoir un accès ipv4… donc même en désactivant IPv6 wan et lan sur le R3, tu garderas un accès internet. Pour que le test fonctionne sur Xbox avec la limitation de vitesse… tu dois te mettre sur always et désactiver les vitesses max au niveau de ping optimiser ! Netduma Fraser and kevin88230 2 Link to comment Share on other sites More sharing options...
kevin88230 Posted February 9, 2024 Author Share Posted February 9, 2024 Thanks I will try this evening @Flou Netduma Fraser 1 Link to comment Share on other sites More sharing options...
kevin88230 Posted February 9, 2024 Author Share Posted February 9, 2024 Problem solved thanks for your help Netduma Fraser 1 Link to comment Share on other sites More sharing options...
Espi411 Posted February 9, 2024 Share Posted February 9, 2024 6 minutes ago, kevin88230 said: Problem solved thanks for your help what was the issue lol cause when i disable the ipv6 stuff my wifi stops working but ethernet still works and i get A+ that way but when i turn them back on it goes back to c sometimes b Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted February 9, 2024 Administrators Share Posted February 9, 2024 7 minutes ago, Espi411 said: what was the issue lol cause when i disable the ipv6 stuff my wifi stops working but ethernet still works and i get A+ that way but when i turn them back on it goes back to c sometimes b The connection should re-establish itself after disabling, if not then reboot and you should be good. Link to comment Share on other sites More sharing options...
Espi411 Posted February 9, 2024 Share Posted February 9, 2024 1 minute ago, Netduma Fraser said: The connection should re-establish itself after disabling, if not then reboot and you should be good. i thought the same thing but when they re connected it was connected with no internet access so when everyones asleep and im gaming i just turn them off in the morning i turn them back on so people can use the wifi not that big of an issue imo but can be annoying if you forget n everyone is like wtf why the wifi out lmao yall doing good stuff keep it up Link to comment Share on other sites More sharing options...
kevin88230 Posted February 9, 2024 Author Share Posted February 9, 2024 1)I returned the netduma to the factory 2) I set the download value 3) I disable IPv6 on LAN and WAN in advanced mode 4) I restarted the netduma Link to comment Share on other sites More sharing options...
kevin88230 Posted February 9, 2024 Author Share Posted February 9, 2024 Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted February 9, 2024 Administrators Share Posted February 9, 2024 1 hour ago, Espi411 said: i thought the same thing but when they re connected it was connected with no internet access so when everyones asleep and im gaming i just turn them off in the morning i turn them back on so people can use the wifi not that big of an issue imo but can be annoying if you forget n everyone is like wtf why the wifi out lmao yall doing good stuff keep it up That's really strange, what phones are they exactly? 1 hour ago, kevin88230 said: 1)I returned the netduma to the factory 2) I set the download value 3) I disable IPv6 on LAN and WAN in advanced mode 4) I restarted the netduma Good results, well done! kevin88230 1 Link to comment Share on other sites More sharing options...
Espi411 Posted February 10, 2024 Share Posted February 10, 2024 12 hours ago, Netduma Fraser said: That's really strange, what phones are they exactly? Good results, well done! iPhone/Samsung same with Alexa and my tvs as well as tablets Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted February 10, 2024 Administrators Share Posted February 10, 2024 For the phones/tablets, if you disable the Random/Private MAC addresses option for the WiFi when you're connected does it continue to happen? Link to comment Share on other sites More sharing options...
Please sign in to comment
You will be able to leave a comment after signing in
