jmoorect1979 Posted January 13, 2024 Posted January 13, 2024 Hello, I just set up my r3 and tried to run the "optimize my ping" setting. I have received the same error every time, "ping optimizer encountered a problem, unable to complete due to external circumstances". Anyone else and is there a fix or solution? Thank you
pollutionblues Posted January 13, 2024 Posted January 13, 2024 The team are aware that Speedtest and ping optimiser are not 100% reliable and are working to solve the issues. For the moment I would suggest running a test on speedtest.net and entering your speeds manually then manually adjusting your Congestion Control sliders in Ping Optimiser > Advanced Netduma Fraser, jmoorect1979 and Zippy 3
jmoorect1979 Posted January 14, 2024 Author Posted January 14, 2024 Thank you for reply, I have done that and figured that would be the best fix until things are worked out.
boothay Posted January 14, 2024 Posted January 14, 2024 ive tried to configure the congestion settings via...manually entering upload and download speeds..........when i go to ping optimiser > advanced...i cannot move either slider. im on firmware 4.0.23
pollutionblues Posted January 14, 2024 Posted January 14, 2024 1 hour ago, boothay said: ive tried to configure the congestion settings via...manually entering upload and download speeds..........when i go to ping optimiser > advanced...i cannot move either slider. im on firmware 4.0.23 Do you have SmartBoost enabled? as you can't adjust the sliders when it is disabled
Administrators Netduma Fraser Posted January 14, 2024 Administrators Posted January 14, 2024 2 hours ago, boothay said: ive tried to configure the congestion settings via...manually entering upload and download speeds..........when i go to ping optimiser > advanced...i cannot move either slider. im on firmware 4.0.23 As above, sounds like you have SmartBOOST disabled
