Setting netduma as primary router for talktalk fibre vdsl
Is it possible to set netduma r1 as primary router with talktalk fibre vdsl or if not how can I set it up with my existing modem router from talktalk
Do you have option on your talktalkrouter to set it to bridge mode or modem mode?
What model of router do you have and is it combo of modem and router or modem and router separte?
I think the Talk Talk one is a modem router combo. You can easily set the Netduma up by just by plugging an Ethernet cable into port one of the Netduma and then plugging the ether end into one of the ethernet ports on the Talk Talk router. If you follow these instructions you should be able to install it pretty quickly :)
Thanks for the replys and my router is a modem/router is called talktalk super router hg635 and i dont think it has a bridge mode from what i can see . im thinking of buying one just wanted to see if it would work before i bought it so if i follow your instructions it should work :)
Also i do have a billion bipac 8800nl which i can use to replace the standard talktalk router if that makes it any easier or gives me better speeds etc
Use the billion in bridge,it's rock solid , I use the 8800axl that way and work flawlessly
