lKoNviiCt Posted July 23, 2015 Posted July 23, 2015 on device manager keep pop up two ip on one device. plz help
Netduma Staff Netduma Crossy Posted July 23, 2015 Netduma Staff Posted July 23, 2015 Don't wory about it I'm not entirely sure why it happens but some of my devices have two IPs and it doesn't cause any problems
lKoNviiCt Posted July 23, 2015 Author Posted July 23, 2015 its conflicting with other devices on the netduma
lKoNviiCt Posted July 23, 2015 Author Posted July 23, 2015 did that last time still pop up with two ip on one device
Netduma Staff Netduma Crossy Posted July 23, 2015 Netduma Staff Posted July 23, 2015 If another device has that IP then the device with two IPs isn't using the duplicate one. You don't need to factory reset - a reboot should fix it but I don't think it should cause an issue. Can all your devices access the internet?
lKoNviiCt Posted July 23, 2015 Author Posted July 23, 2015 what reboot both router. or just the netduma
Netduma Staff Netduma Crossy Posted July 23, 2015 Netduma Staff Posted July 23, 2015 what reboot both router. or just the netduma Just the Netduma would probably sort it - but if both devices have an internet connection I don't think you should worry
Netduma Staff Netduma Crossy Posted July 23, 2015 Netduma Staff Posted July 23, 2015 does not say it Connected Sorry, what do you mean? So the device has no internet connection?
lukasz Posted July 23, 2015 Posted July 23, 2015 Yebs just take those 2 devices and use internet on them at this same time and see if you can do it even though its say not connected on duma interface.
lKoNviiCt Posted July 23, 2015 Author Posted July 23, 2015 Sorry, what do you mean? So the device has no internet connection? yes crossy
Netduma Staff Netduma Crossy Posted July 23, 2015 Netduma Staff Posted July 23, 2015 yes crossy Have you tried restarting the router? Also try disconnecting and re-connecting the device.
Netduma Staff Netduma Crossy Posted July 23, 2015 Netduma Staff Posted July 23, 2015 yep Whats the error when you try to access the internet? And is it only one device?
lKoNviiCt Posted July 23, 2015 Author Posted July 23, 2015 now showing up 3 ip on one device ill give up now with this my sky tv box say its Connected but on the netduma its say im not Connected
Netduma Staff Netduma Crossy Posted July 23, 2015 Netduma Staff Posted July 23, 2015 now showing up 3 ip on one device ill give up now with this Ok. As I said before, I wouldn't worry if it is showing more than one IP. If you're concerned about it you could take a screen shot and post it here. Is your device now connecting properly?
Netduma Staff Netduma Crossy Posted July 23, 2015 Netduma Staff Posted July 23, 2015 how do yo take screen shot? This explains how to take a screen shot.
AsNCo Posted July 23, 2015 Posted July 23, 2015 on device manager keep pop up two ip on one device. plz help I think you have a case of one of your device having a Static IP address fixed on your device. Let's assume the first device is a PS4. On the PS4, you made a Static IP address of 192.168.88.201. On the second device, which I assume to be your PC, you did not have any Static IP addresses. So first, you have not turned on the PS4 so it is not connected to the Netduma, the Netduma's DHCP server will give away the IP address of 192.168.88.201 to your PC that connected to the router first. But then, you turn on your PS4 and it also has the same IP address. Thus, the conflict happens. My above scenario is the usual case that you might be experiencing. The Netduma's DHCP server starts at 192.168.88.201 and ends at 192.168.88.250 So I would highly suggest you either .... 1) Make a Static IP address on your PS4 or PC so that it is not in the DHCP server range like 192.168.88.2 all the way to 192.168.88.200. Thus, there will be no chances of a conflict of IP addresses. 2) Go to Settings -> Lan -> Look under DHCP and completely change the DHCP server range from the default . So I would suggest 192.168.88.101 to 192.168.88.200. (This option is better if you do not want to mess with your PC or PS4 connection settings or do not know which device has the Static IP address that caused this problem)
lKoNviiCt Posted July 23, 2015 Author Posted July 23, 2015 I think you have a case of one of your device having a Static IP address fixed on your device. Let's assume the first device is a PS4. On the PS4, you made a Static IP address of 192.168.88.201. On the second device, which I assume to be your PC, you did not have any Static IP addresses. So first, you have not turned on the PS4 so it is not connected to the Netduma, the Netduma's DHCP server will give away the IP address of 192.168.88.201 to your PC that connected to the router first. But then, you turn on your PS4 and it also has the same IP address. Thus, the conflict happens. My above scenario is the usual case that you might be experiencing. The Netduma's DHCP server starts at 192.168.88.201 and ends at 192.168.88.250 So I would highly suggest you either .... 1) Make a Static IP address on your PS4 or PC so that it is not in the DHCP server range like 192.168.88.2 all the way to 192.168.88.200. Thus, there will be no chances of a conflict of IP addresses. 2) Go to Settings -> Lan -> Look under DHCP and completely change the DHCP server range from the default . So I would suggest 192.168.88.101 to 192.168.88.200. (This option is better if you do not want to mess with your PC or PS4 connection settings or do not know which device has the Static IP address that caused this problem) thank you for that.But i do not own an ps4 only xbox one. now showing up 1 ip on every device. I just roboot netduma and everything good
Netduma Staff Netduma Crossy Posted July 23, 2015 Netduma Staff Posted July 23, 2015 thank you for that.But i do not own an ps4 only xbox one. now showing up 1 ip on every device. I just roboot netduma and everything good Awesome! As this is sorted I'll close the thread - if you have any more problem make a new one
