ij4xs Posted October 25, 2022 Posted October 25, 2022 Been through a bunch of posts and it seems like this is a known issue, but hopefully I can help with nailing down some of the "when" and "what" that appears to be happening with it. I've personally had this happen twice with port forwarding and possibly a few more times with the netgear openvpn service. I'll usually find out the port forwarding is broken when I can't reach my game servers or one of my VPN servers. The netgear openvpn will come back online by disabling and re-enabling the service. The only way I've found to recreate the port forwarding is to factory reset and recreate everything from scratch. I run a home lab with my game servers so I am regularly adjusting DNS and DHCP settings on the xr1000 and right now my theory is that changing settings on the LAN, WAN, or Internet pages somehow affects the port forwarding. Where I need to factory reset again I'll be checking my port forwarding page in between each change I make. Current port forward screen: Re-adding one of the "missing" rules:
Administrators Netduma Fraser Posted October 25, 2022 Administrators Posted October 25, 2022 It is a known issue that the port forwarding entries seem to disappear so if you go to add a new rule where the port is the same as one of those entries you'll get that message. This is something NG is fixing for the next version I believe. If you set all the rules you need after a factory reset and don't change them then they should be okay but are you saying when using OpenVPN it causes the entries to disappear?
ij4xs Posted November 1, 2022 Author Posted November 1, 2022 I'm hoping to figure out which other setting it is that makes them disappear. Without a factory reset the OpenVPN settings are the only ones that I can re-enable. Once I'm done with a giant file copy I'll be factory resetting, getting everything set back up and I'll closely monitor any changes and check on the port forwarding between each change. I'm also planning on getting the rest of the settings configured and then doing the OpenVPN and then very last I'll set up the static port forwards.
Administrators Netduma Fraser Posted November 1, 2022 Administrators Posted November 1, 2022 It would be great if you are able to find the causes and then we can pass that onto NG to aid them in their fix. It's entirely possible this is already fixed on the next version which I'm hoping isn't too far off now.
ij4xs Posted November 7, 2022 Author Posted November 7, 2022 okay long post incoming, but I had a chance to reset the xr1000, and I've got nothing concrete yet. getting lots of "timestamp expired" when I was only on a screen for a minute also the interface reloading, sometimes long enough for the message "you are no longer connected to your router" to show --- I am using static addressing while setting up and am on ethernet reset-1: set router lan to 192.168.0.1 set dhcp to off and max address to 99 ---applied set manual public DNS to 10.66.66.1 ---applied uploaded device names ---wait for names to show add 3 static routes: named, yes private, yes active, all metric 2 add 9 port fowards turn on vpn ---applied set up DDNS ---applied turn on traffic logging no limit reset on 1st of month ---applied !!!broken port forwarding reset-2: set up a port forward ---applied changed internal LAN IP ---applied !!!broken port forwarding it recovered this time after the interface reset while I was on admin -> backup settings and had hit the Erase button add 3 static routes: named, yes private, yes active, all metric 2 set manual public DNS to 10.66.66.1 ---applied set dhcp max ip to 99 ---applied turn off dhcp ---applied set account name on internet page ---applied set device name ---applied turn off DLNA Media server ---applied disable all ReadySHARE Storage ---applied turn on DDNS ---applied turn on router hosted VPN for "all sites on the internet & home network" --- applied set wifi: on: ax, ofdma 2.4, ofdma 5.0, smart connect, ssid broadcast. off: 20/40 coexistence. max speed and max power 2.4 & 5.0. ---applied set wifi ssid and pass, wpa2-personal[aes] ---applied NAT filtering to open ---applied !!!broken port forwarding added new port forward ---applied -> new rule shows up, old does not, openVPN works. adding missing forwarding gives duplicate port message NAT filtering back to secured ---applied port forwarding same status reset-3: set one port forward set router lan to 192.168.0.1 and dhcp max to 99 ---applied set nat to open and sip alg to off ---applied turn on traffic meter (same as above) ---applied set account name ---applied set manual dns ---applied apply above wifi options ---applied apply wifi ssid, password and channel ---applied turn off media server ---applied turn off ready share ---applied enable mu-mimo ---applied static route 1 ---applied static route 2 ---applied static route 3 ---applied DDNS setup ---applied turned on openvpn ---applied tested port forward vpn and openvpn ---done adding rest of port forwards: 8 more apply device names using the import dialog ---applied congestion control to always ---applied download and upload speeds set to 90% (900mbps) ---applied something about reset-3 worked. still fine after an hour still working after two days
Administrators Netduma Fraser Posted November 7, 2022 Administrators Posted November 7, 2022 That is very strange, the way you've listed the steps you did, is that in order of when you did it?
ij4xs Posted November 7, 2022 Author Posted November 7, 2022 Right, the order in the list is the order I followed.
Administrators Netduma Fraser Posted November 7, 2022 Administrators Posted November 7, 2022 It's weird given in reset 2 & 3 that you started in the same way and one caused it to break and the other didn't, which would lead me to believe there isn't necessarily one way to always reproduce it
ij4xs Posted November 7, 2022 Author Posted November 7, 2022 Yeah, that's been my worry that it's more likely something triggers a bad save or a save to a bad bit of NAND or something similar. In the past I've had it trigger on changing LAN settings or the public DNS setting. At this point I'm checking my port forwards as the router picks up new devices and I update the device names and types.
Administrators Netduma Fraser Posted November 7, 2022 Administrators Posted November 7, 2022 Best to let Netgear figure it out I think, you've done really well to prove that there is no set way to reproduce it, well done on getting it working as well! ij4xs 1
ij4xs Posted November 7, 2022 Author Posted November 7, 2022 X-D Thanks! We'll see if my #3 steps work the next time it all breaks or not! Do we happen to have any ETA on when this fix would/could come out? It's frustrating enough to me that I might get an r2 just to not have to deal with this for a bit.
Administrators Netduma Fraser Posted November 7, 2022 Administrators Posted November 7, 2022 The next firmware isn't too far off, I haven't had a chance to test whether this particular issue is fixed but I'll pass it onto the team to check.
iceman007 Posted June 29, 2023 Posted June 29, 2023 I've been experiencing this issue since about August when the router just completely factory reset itself overnight, wiping itself clean. Since then whatever static IPs and port forwards I set up on that first day, are what I'm stuck with now. I can't add anymore static IP devices either, they appear on the list but then just disappear. As far as the port forward rules, the 5 or so I have set up after the factory reset are working without issues, but every time I add more, they appear on the list but don't do anything. They don't work and a Router reboot wipes them off the list. The last post on here is from November 2022 saying a firmware update isn't far off. It's now 7 months later and still nothing on how to resolve this issue. Obvioulsy this is a major problem, a simple google search reveals a bunch of posts from here, Netgear and Reddit, yet no one seems to be doing anything about it. Can SOMEONE please take some responsibility for this and fix it! Very poor form by both Netgear and DumaOS on this. (XR1000 running latest firmare V1.0.0.68_1.0.54)
Administrators Netduma Fraser Posted June 29, 2023 Administrators Posted June 29, 2023 I'd suggest reupgrading the firmware using the TFTP method, this bypasses the boot process and any issues there then once done do a factory reset for the freshest install possible: https://kb.netgear.com/000059634/How-do-I-upload-firmware-to-my-NETGEAR-router-using-TFTP-from-the-Microsoft-Windows-Command-Prompt?article=000059634 and see if it works after that. If you reboot by unplugging the router without having done a software reboot (which acts as a hard save) then it could wipe settings.
ij4xs Posted July 25, 2023 Author Posted July 25, 2023 After a very long clean streak my xr1000 finally broke the port forwards again. The setting I changed that seemed to trigger it was changing from DHCP DNS to manual DNS and providing the entries. I've put my spare router in to take care of my house and the xr1000 I've left as is for the moment. Are there any logs or crash info I can get from it to pass on here? If there's nothing to gather from the xr1000 should I try the TFTP update method? EDIT: I changed the upstream DNS on the Netgear Settings -> Setup -> Internet Setup page.
Administrators Netduma Fraser Posted July 28, 2023 Administrators Posted July 28, 2023 On 7/26/2023 at 12:43 AM, ij4xs said: After a very long clean streak my xr1000 finally broke the port forwards again. The setting I changed that seemed to trigger it was changing from DHCP DNS to manual DNS and providing the entries. I've put my spare router in to take care of my house and the xr1000 I've left as is for the moment. Are there any logs or crash info I can get from it to pass on here? If there's nothing to gather from the xr1000 should I try the TFTP update method? EDIT: I changed the upstream DNS on the Netgear Settings -> Setup -> Internet Setup page. Sorry to hear that, you could grab logs from the System Information page when it happens, I'm not sure if much will show there though. TFTP would be a good idea just in case there are any errors in the boot process.
ij4xs Posted July 28, 2023 Author Posted July 28, 2023 Unfortunately the logs don't go back far enough. I'll give it one try of setting it up and breaking it on purpose to get log info and then I'll run the TFTP firmware upload. Below is what is in the logs at the moment. They appear to go as far back as when I switched the routers (the date is wrong as I fixed NTP just now). Jan 26 03:59:17 pandorasbox local1.notice CEVENT_APP[7622]: 1643169557394 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jan 26 03:59:21 pandorasbox local1.notice CEVENT_APP[7622]: 1643169561489 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jan 26 03:59:26 pandorasbox local1.notice CEVENT_APP[7622]: 1643169566540 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jan 26 03:59:30 pandorasbox local1.notice CEVENT_APP[7622]: 1643169570610 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jan 26 03:59:34 pandorasbox local1.notice CEVENT_APP[7622]: 1643169574658 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jan 26 03:59:39 pandorasbox local1.notice CEVENT_APP[7622]: 1643169579714 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jan 26 03:59:43 pandorasbox local1.notice CEVENT_APP[7622]: 1643169583766 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jan 26 03:59:47 pandorasbox local1.notice CEVENT_APP[7622]: 1643169587817 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jan 26 03:59:51 pandorasbox local1.notice CEVENT_APP[7622]: 1643169591868 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jan 25 20:59:51 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 20:59:52 pandorasbox user.emerg httpd: ****handle_get(675) 71 Jan 25 20:59:52 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 20:59:52 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 25 20:59:52 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 20:59:52 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 25 20:59:52 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 20:59:52 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 20:59:52 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 20:59:52 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 20:59:52 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 20:59:52 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 20:59:52 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 20:59:52 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 20:59:52 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 20:59:52 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 25 20:59:52 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 20:59:52 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 20:59:52 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 20:59:52 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 20:59:52 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 20:59:52 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 20:59:52 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 20:59:52 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 20:59:52 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 20:59:52 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 20:59:52 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 20:59:52 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 20:59:52 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 20:59:52 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 20:59:52 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 20:59:52 pandorasbox user.emerg httpd: ****handle_get(675) 71 Jan 25 20:59:52 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 20:59:52 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 25 20:59:52 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 20:59:52 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 25 20:59:52 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 20:59:52 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 25 20:59:52 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 20:59:52 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 20:59:52 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 20:59:52 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 20:59:52 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 20:59:52 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 20:59:52 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 20:59:52 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 26 03:59:55 pandorasbox local1.notice CEVENT_APP[7622]: 1643169595919 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jan 26 04:00:01 pandorasbox local1.notice CEVENT_APP[7622]: 1643169601010 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jan 26 04:00:05 pandorasbox local1.notice CEVENT_APP[7622]: 1643169605067 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jan 25 21:00:08 pandorasbox user.emerg httpd: ****handle_post(1418) 73 Jan 25 21:00:08 pandorasbox user.emerg httpd: ****handle_post(1470) 73 Jan 25 21:00:08 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:00:08 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 25 21:00:08 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:00:08 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 25 21:00:08 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:00:08 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:00:08 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:00:08 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:00:08 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:00:08 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:00:08 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:00:08 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:00:08 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:00:08 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 25 21:00:08 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:00:09 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:00:09 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:00:09 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:00:09 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:00:09 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:00:09 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:00:09 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:00:09 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:00:09 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:00:09 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:00:09 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:00:09 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:00:09 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:00:09 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:00:09 pandorasbox user.emerg httpd: ****handle_get(675) 71 Jan 26 04:00:09 pandorasbox local1.notice CEVENT_APP[7622]: 1643169609108 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jan 25 21:00:09 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:00:09 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 25 21:00:09 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:00:09 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 25 21:00:09 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:00:09 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 25 21:00:09 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:00:09 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:00:09 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:00:09 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:00:09 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:00:09 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:00:09 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:00:09 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 26 04:00:13 pandorasbox local1.notice CEVENT_APP[7622]: 1643169613188 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jan 26 04:00:17 pandorasbox local1.notice CEVENT_APP[7622]: 1643169617236 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jan 26 04:00:21 pandorasbox local1.notice CEVENT_APP[7622]: 1643169621286 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jan 26 04:00:25 pandorasbox local1.notice CEVENT_APP[7622]: 1643169625337 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jan 26 04:00:29 pandorasbox local1.notice CEVENT_APP[7622]: 1643169629387 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jan 26 04:00:33 pandorasbox local1.notice CEVENT_APP[7622]: 1643169633460 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jan 26 04:00:37 pandorasbox local1.notice CEVENT_APP[7622]: 1643169637508 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jan 26 04:00:41 pandorasbox local1.notice CEVENT_APP[7622]: 1643169641581 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jan 26 04:00:45 pandorasbox local1.notice CEVENT_APP[7622]: 1643169645628 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jan 26 04:00:50 pandorasbox local1.notice CEVENT_APP[7622]: 1643169650682 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jan 26 04:00:54 pandorasbox local1.notice CEVENT_APP[7622]: 1643169654734 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jan 25 21:00:55 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:00:55 pandorasbox user.emerg httpd: ****handle_get(675) 71 Jan 25 21:00:55 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:00:55 pandorasbox user.emerg httpd: ****handle_get(675) 71 Jan 25 21:00:55 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:00:55 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 25 21:00:55 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:00:55 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 25 21:00:55 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:00:55 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:00:55 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:00:55 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:00:55 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:00:55 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:00:55 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:00:55 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:00:55 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:00:55 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 26 04:00:59 pandorasbox local1.notice CEVENT_APP[7622]: 1643169659790 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jan 26 04:01:03 pandorasbox local1.notice CEVENT_APP[7622]: 1643169663840 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jan 25 21:01:05 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:01:05 pandorasbox user.emerg httpd: ****handle_get(675) 71 Jan 25 21:01:05 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:01:05 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 25 21:01:05 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:01:05 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 25 21:01:05 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:01:05 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:01:05 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:01:05 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:01:05 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:01:05 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:01:05 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:01:05 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:01:05 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:01:05 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 26 04:01:07 pandorasbox local1.notice CEVENT_APP[7622]: 1643169667918 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jan 26 04:01:11 pandorasbox local1.notice CEVENT_APP[7622]: 1643169671966 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jan 25 21:01:15 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:01:15 pandorasbox user.emerg httpd: ****handle_get(675) 71 Jan 25 21:01:15 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:01:15 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 25 21:01:15 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:01:15 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 25 21:01:15 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:01:15 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:01:15 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:01:15 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:01:15 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:01:15 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:01:15 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:01:15 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:01:15 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:01:15 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 26 04:01:16 pandorasbox local1.notice CEVENT_APP[7622]: 1643169676031 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jan 26 04:01:20 pandorasbox local1.notice CEVENT_APP[7622]: 1643169680096 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jan 26 04:01:24 pandorasbox local1.notice CEVENT_APP[7622]: 1643169684153 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jan 25 21:01:25 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:01:25 pandorasbox user.emerg httpd: ****handle_get(675) 71 Jan 25 21:01:25 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:01:25 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 25 21:01:25 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:01:25 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 25 21:01:25 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:01:25 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:01:25 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:01:25 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:01:25 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:01:25 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:01:25 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:01:25 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 25 21:01:25 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:01:25 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 26 04:01:28 pandorasbox local1.notice CEVENT_APP[7622]: 1643169688209 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jan 26 04:01:32 pandorasbox local1.notice CEVENT_APP[7622]: 1643169692258 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jan 25 21:01:35 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:01:35 pandorasbox user.emerg httpd: ****handle_get(675) 71 Jan 25 21:01:35 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:01:35 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 25 21:01:35 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:01:35 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 25 21:01:35 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:01:35 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:01:35 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:01:35 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:01:35 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:01:35 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:01:35 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:01:35 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:01:35 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:01:35 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 26 04:01:37 pandorasbox local1.notice CEVENT_APP[7622]: 1643169697315 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jan 26 04:01:42 pandorasbox local1.notice CEVENT_APP[7622]: 1643169702372 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jan 25 21:01:45 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:01:45 pandorasbox user.emerg httpd: ****handle_get(675) 71 Jan 25 21:01:45 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:01:45 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 25 21:01:45 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:01:45 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 25 21:01:45 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:01:45 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:01:45 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:01:45 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:01:45 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:01:45 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:01:45 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:01:45 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:01:45 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:01:45 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 26 04:01:49 pandorasbox local1.notice CEVENT_APP[7622]: 1643169709441 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jan 26 04:01:55 pandorasbox local1.notice CEVENT_APP[7622]: 1643169715529 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jan 25 21:01:55 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:01:55 pandorasbox user.emerg httpd: ****handle_get(675) 71 Jan 25 21:01:55 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:01:55 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 25 21:01:55 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:01:55 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 25 21:01:55 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:01:55 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:01:55 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:01:55 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:01:55 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:01:55 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:01:55 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:01:55 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 25 21:01:55 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:01:55 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 26 04:01:59 pandorasbox local1.notice CEVENT_APP[7622]: 1643169719576 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jan 26 04:02:03 pandorasbox local1.notice CEVENT_APP[7622]: 1643169723630 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jan 25 21:02:05 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:05 pandorasbox user.emerg httpd: ****handle_get(675) 71 Jan 25 21:02:05 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:05 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 25 21:02:05 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:05 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 25 21:02:05 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:05 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:02:05 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:05 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:02:05 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:05 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:02:05 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:05 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:02:05 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:05 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 26 04:02:07 pandorasbox local1.notice CEVENT_APP[7622]: 1643169727686 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jan 26 04:02:11 pandorasbox local1.notice CEVENT_APP[7622]: 1643169731765 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jan 26 04:02:15 pandorasbox local1.notice CEVENT_APP[7622]: 1643169735837 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jan 25 21:02:15 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:15 pandorasbox user.emerg httpd: ****handle_get(675) 71 Jan 25 21:02:15 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:15 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 25 21:02:16 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:16 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 25 21:02:16 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:16 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:02:16 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:16 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:02:16 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:16 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:02:16 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:16 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:02:16 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:16 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 26 04:02:20 pandorasbox local1.notice CEVENT_APP[7622]: 1643169740894 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jan 26 04:02:24 pandorasbox local1.notice CEVENT_APP[7622]: 1643169744946 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jan 25 21:02:26 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:26 pandorasbox user.emerg httpd: ****handle_get(675) 71 Jan 25 21:02:26 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:26 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 25 21:02:26 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:26 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 25 21:02:26 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:26 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:02:26 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:26 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:02:26 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:26 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:02:26 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:26 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:02:26 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:26 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 26 04:02:28 pandorasbox local1.notice CEVENT_APP[7622]: 1643169748998 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jan 26 04:02:33 pandorasbox local1.notice CEVENT_APP[7622]: 1643169753052 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jan 25 21:02:36 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:36 pandorasbox user.emerg httpd: ****handle_get(675) 71 Jan 25 21:02:36 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:36 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 25 21:02:36 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:36 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 25 21:02:36 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:36 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:02:36 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:36 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:02:36 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:36 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:02:36 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:36 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:02:36 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:36 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 26 04:02:37 pandorasbox local1.notice CEVENT_APP[7622]: 1643169757116 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jan 26 04:02:41 pandorasbox local1.notice CEVENT_APP[7622]: 1643169761197 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jan 26 04:02:45 pandorasbox local1.notice CEVENT_APP[7622]: 1643169765251 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jan 25 21:02:46 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:46 pandorasbox user.emerg httpd: ****handle_get(675) 71 Jan 25 21:02:46 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:46 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 25 21:02:46 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:46 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 25 21:02:46 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:46 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:02:46 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:46 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:02:46 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:46 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:02:46 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:46 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:02:46 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:46 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 26 04:02:49 pandorasbox local1.notice CEVENT_APP[7622]: 1643169769325 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jan 25 21:02:53 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:53 pandorasbox user.emerg httpd: ****handle_get(675) 71 Jan 25 21:02:53 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:53 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 25 21:02:53 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:53 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 25 21:02:53 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:53 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:02:53 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:53 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:02:53 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:53 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:02:53 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:53 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:02:53 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:53 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:02:53 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:53 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 25 21:02:53 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:53 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:02:53 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:53 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:02:53 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:53 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:02:53 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:53 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:02:53 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:53 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:02:53 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:53 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:02:53 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:53 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:02:53 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:53 pandorasbox user.emerg httpd: ****handle_get(675) 71 Jan 25 21:02:53 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:53 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 25 21:02:53 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:53 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 25 21:02:53 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:53 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 25 21:02:53 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:53 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:02:53 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:53 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:02:53 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:53 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:02:53 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:02:53 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 26 04:02:54 pandorasbox local1.notice CEVENT_APP[7622]: 1643169774378 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jan 26 04:02:58 pandorasbox local1.notice CEVENT_APP[7622]: 1643169778428 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jan 26 04:03:02 pandorasbox local1.notice CEVENT_APP[7622]: 1643169782481 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jan 25 21:03:02 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:03:02 pandorasbox user.emerg httpd: ****handle_get(675) 71 Jan 25 21:03:02 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:03:02 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 25 21:03:02 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:03:02 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 25 21:03:02 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:03:02 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:03:02 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:03:02 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:03:02 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:03:02 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:03:02 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:03:02 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:03:02 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:03:02 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 25 21:03:02 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:03:02 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:03:02 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:03:02 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:03:02 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:03:02 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:03:02 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:03:02 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:03:02 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:03:02 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:03:02 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:03:02 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:03:02 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:03:02 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:03:02 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:03:02 pandorasbox user.emerg httpd: ****handle_get(675) 71 Jan 25 21:03:02 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:03:02 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 25 21:03:02 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:03:02 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 25 21:03:02 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:03:02 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jan 25 21:03:02 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:03:02 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:03:02 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:03:02 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:03:02 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:03:02 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 25 21:03:02 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jan 25 21:03:02 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jan 26 04:03:06 pandorasbox local1.notice CEVENT_APP[7622]: 1643169786534 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jan 26 04:03:11 pandorasbox local1.notice CEVENT_APP[7622]: 1643169791594 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jan 26 04:03:15 pandorasbox local1.notice CEVENT_APP[7622]: 1643169795646 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jan 25 21:03:19 pandorasbox user.emerg httpd: ****handle_post(1418) 73 Jul 28 16:03:58 pandorasbox local1.notice CEVENT_APP[7622]: 1690560238949 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 10:03:59 pandorasbox user.emerg httpd: ****handle_post(1470) 73 Jul 28 16:04:06 pandorasbox local1.notice CEVENT_APP[7622]: 1690560246008 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:04:10 pandorasbox local1.notice CEVENT_APP[7622]: 1690560250060 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:04:14 pandorasbox local1.notice CEVENT_APP[7622]: 1690560254132 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:04:18 pandorasbox local1.notice CEVENT_APP[7622]: 1690560258184 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:04:23 pandorasbox local1.notice CEVENT_APP[7622]: 1690560263239 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:04:27 pandorasbox local1.notice CEVENT_APP[7622]: 1690560267291 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:04:31 pandorasbox local1.notice CEVENT_APP[7622]: 1690560271340 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:04:36 pandorasbox local1.notice CEVENT_APP[7622]: 1690560276434 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 10:04:39 pandorasbox cron.err crond[28755]: time disparity of 789841 minutes detected 98 Jul 28 16:04:40 pandorasbox local1.notice CEVENT_APP[7622]: 1690560280482 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:04:44 pandorasbox local1.notice CEVENT_APP[7622]: 1690560284532 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:04:49 pandorasbox local1.notice CEVENT_APP[7622]: 1690560289631 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:04:53 pandorasbox local1.notice CEVENT_APP[7622]: 1690560293682 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:04:57 pandorasbox local1.notice CEVENT_APP[7622]: 1690560297749 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:05:03 pandorasbox local1.notice CEVENT_APP[7622]: 1690560303809 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:05:10 pandorasbox local1.notice CEVENT_APP[7622]: 1690560310872 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:05:14 pandorasbox local1.notice CEVENT_APP[7622]: 1690560314924 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:05:18 pandorasbox local1.notice CEVENT_APP[7622]: 1690560318978 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:05:23 pandorasbox local1.notice CEVENT_APP[7622]: 1690560323033 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 10:05:23 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:05:23 pandorasbox user.emerg httpd: ****handle_get(675) 71 Jul 28 10:05:23 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:05:23 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jul 28 10:05:23 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:05:23 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jul 28 10:05:23 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:05:23 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:05:23 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:05:23 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:05:23 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:05:23 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:05:23 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:05:23 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:05:23 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:05:23 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:05:23 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:05:23 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:05:23 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:05:23 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:05:23 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:05:23 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jul 28 10:05:23 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:05:23 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:05:23 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:05:23 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:05:23 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:05:23 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:05:23 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:05:23 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:05:23 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:05:23 pandorasbox user.emerg httpd: ****handle_get(675) 71 Jul 28 10:05:23 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:05:23 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jul 28 10:05:24 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:05:24 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jul 28 10:05:24 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:05:24 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jul 28 10:05:24 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:05:24 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:05:24 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:05:24 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:05:24 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:05:24 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:05:24 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:05:24 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 16:05:27 pandorasbox local1.notice CEVENT_APP[7622]: 1690560327083 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:05:31 pandorasbox local1.notice CEVENT_APP[7622]: 1690560331135 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:05:35 pandorasbox local1.notice CEVENT_APP[7622]: 1690560335188 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 10:05:35 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:05:35 pandorasbox user.emerg httpd: ****handle_get(675) 71 Jul 28 10:05:35 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:05:35 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jul 28 10:05:35 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:05:35 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:05:35 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:05:35 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jul 28 10:05:35 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:05:35 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:05:35 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:05:35 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:05:35 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:05:35 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:05:35 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:05:35 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jul 28 10:05:35 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:05:35 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:05:35 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:05:35 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:05:35 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:05:35 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:05:35 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:05:35 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:05:35 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:05:35 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:05:35 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:05:35 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:05:35 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:05:35 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:05:35 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:05:35 pandorasbox user.emerg httpd: ****handle_get(675) 71 Jul 28 10:05:35 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:05:35 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jul 28 10:05:35 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:05:35 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jul 28 10:05:35 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:05:35 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jul 28 10:05:35 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:05:35 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:05:35 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:05:35 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:05:35 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:05:35 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:05:35 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:05:35 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 16:05:39 pandorasbox local1.notice CEVENT_APP[7622]: 1690560339242 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:05:43 pandorasbox local1.notice CEVENT_APP[7622]: 1690560343292 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:05:48 pandorasbox local1.notice CEVENT_APP[7622]: 1690560348373 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:05:52 pandorasbox local1.notice CEVENT_APP[7622]: 1690560352420 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:05:56 pandorasbox local1.notice CEVENT_APP[7622]: 1690560356474 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:06:00 pandorasbox local1.notice CEVENT_APP[7622]: 1690560360545 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:06:05 pandorasbox local1.notice CEVENT_APP[7622]: 1690560365598 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:06:09 pandorasbox local1.notice CEVENT_APP[7622]: 1690560369676 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:06:13 pandorasbox local1.notice CEVENT_APP[7622]: 1690560373761 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:06:17 pandorasbox local1.notice CEVENT_APP[7622]: 1690560377809 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:06:21 pandorasbox local1.notice CEVENT_APP[7622]: 1690560381860 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:06:25 pandorasbox local1.notice CEVENT_APP[7622]: 1690560385911 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:06:29 pandorasbox local1.notice CEVENT_APP[7622]: 1690560389958 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:06:34 pandorasbox local1.notice CEVENT_APP[7622]: 1690560394007 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:06:38 pandorasbox local1.notice CEVENT_APP[7622]: 1690560398085 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:06:42 pandorasbox local1.notice CEVENT_APP[7622]: 1690560402134 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:06:46 pandorasbox local1.notice CEVENT_APP[7622]: 1690560406186 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:06:50 pandorasbox local1.notice CEVENT_APP[7622]: 1690560410234 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:06:54 pandorasbox local1.notice CEVENT_APP[7622]: 1690560414298 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:06:59 pandorasbox local1.notice CEVENT_APP[7622]: 1690560419354 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:07:03 pandorasbox local1.notice CEVENT_APP[7622]: 1690560423414 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:07:07 pandorasbox local1.notice CEVENT_APP[7622]: 1690560427475 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:07:16 pandorasbox local1.notice CEVENT_APP[7622]: 1690560436545 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:07:20 pandorasbox local1.notice CEVENT_APP[7622]: 1690560440595 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:07:24 pandorasbox local1.notice CEVENT_APP[7622]: 1690560444646 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:07:28 pandorasbox local1.notice CEVENT_APP[7622]: 1690560448694 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:07:32 pandorasbox local1.notice CEVENT_APP[7622]: 1690560452742 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:07:36 pandorasbox local1.notice CEVENT_APP[7622]: 1690560456796 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:07:40 pandorasbox local1.notice CEVENT_APP[7622]: 1690560460848 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:07:45 pandorasbox local1.notice CEVENT_APP[7622]: 1690560465907 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:07:49 pandorasbox local1.notice CEVENT_APP[7622]: 1690560469975 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:07:54 pandorasbox local1.notice CEVENT_APP[7622]: 1690560474025 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:07:58 pandorasbox local1.notice CEVENT_APP[7622]: 1690560478074 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:08:02 pandorasbox local1.notice CEVENT_APP[7622]: 1690560482136 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:08:06 pandorasbox local1.notice CEVENT_APP[7622]: 1690560486188 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:08:12 pandorasbox local1.notice CEVENT_APP[7622]: 1690560492273 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:08:16 pandorasbox local1.notice CEVENT_APP[7622]: 1690560496321 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:08:20 pandorasbox local1.notice CEVENT_APP[7622]: 1690560500379 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:08:26 pandorasbox local1.notice CEVENT_APP[7622]: 1690560506439 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:08:30 pandorasbox local1.notice CEVENT_APP[7622]: 1690560510491 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:08:34 pandorasbox local1.notice CEVENT_APP[7622]: 1690560514574 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:08:38 pandorasbox local1.notice CEVENT_APP[7622]: 1690560518620 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:08:42 pandorasbox local1.notice CEVENT_APP[7622]: 1690560522699 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:08:46 pandorasbox local1.notice CEVENT_APP[7622]: 1690560526746 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:08:50 pandorasbox local1.notice CEVENT_APP[7622]: 1690560530804 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:08:54 pandorasbox local1.notice CEVENT_APP[7622]: 1690560534877 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:08:58 pandorasbox local1.notice CEVENT_APP[7622]: 1690560538928 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 10:09:00 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:09:00 pandorasbox user.emerg httpd: ****handle_get(675) 71 Jul 28 10:09:00 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:09:00 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jul 28 10:09:00 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:09:00 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:09:00 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:09:00 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:09:00 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:09:00 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:09:00 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:09:00 pandorasbox user.emerg httpd: ****handle_get(926) 71 Jul 28 10:09:00 pandorasbox user.emerg httpd: ****handle_post(1441) 73 Jul 28 10:09:00 pandorasbox user.emerg httpd: ****handle_post(1454) 73 Jul 28 10:09:00 pandorasbox user.emerg httpd: ****handle_post(1470) 73 Jul 28 10:09:00 pandorasbox user.emerg httpd: ****handle_get(929) 71 Jul 28 10:09:01 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:09:01 pandorasbox user.emerg httpd: ****handle_get(675) 71 Jul 28 10:09:01 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:09:01 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:09:01 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:09:01 pandorasbox user.emerg httpd: ****handle_get(675) 71 Jul 28 10:09:01 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:09:01 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jul 28 10:09:01 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:09:01 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:09:01 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:09:01 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:09:01 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:09:01 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jul 28 10:09:01 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:09:01 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:09:01 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:09:01 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:09:01 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:09:01 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:09:01 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:09:01 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:09:01 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:09:01 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:09:01 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:09:01 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:09:01 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:09:01 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:09:01 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:09:01 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:09:01 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:09:01 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:09:01 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:09:01 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jul 28 10:09:01 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 16:09:03 pandorasbox local1.notice CEVENT_APP[7622]: 1690560543983 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 10:09:06 pandorasbox user.emerg httpd: ****handle_get(675) 71 Jul 28 10:09:06 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:09:06 pandorasbox user.emerg httpd: ****handle_get(675) 71 Jul 28 10:09:06 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:09:06 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jul 28 10:09:06 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:09:06 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jul 28 10:09:06 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:09:06 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:09:06 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:09:06 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:09:06 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:09:06 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:09:06 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:09:06 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:09:06 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:09:06 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:09:06 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:09:06 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jul 28 10:09:06 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:09:06 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:09:06 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:09:06 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:09:06 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:09:06 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:09:06 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:09:06 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:09:06 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:09:06 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:09:06 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:09:06 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:09:07 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:09:07 pandorasbox user.emerg httpd: ****handle_get(675) 71 Jul 28 10:09:07 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:09:07 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jul 28 10:09:07 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:09:07 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jul 28 10:09:07 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:09:07 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jul 28 10:09:07 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:09:07 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:09:07 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:09:07 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:09:07 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:09:07 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:09:07 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:09:07 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 16:09:08 pandorasbox local1.notice CEVENT_APP[7622]: 1690560548120 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:09:12 pandorasbox local1.notice CEVENT_APP[7622]: 1690560552218 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:09:16 pandorasbox local1.notice CEVENT_APP[7622]: 1690560556333 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:09:21 pandorasbox local1.notice CEVENT_APP[7622]: 1690560561440 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:09:25 pandorasbox local1.notice CEVENT_APP[7622]: 1690560565581 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:09:29 pandorasbox local1.notice CEVENT_APP[7622]: 1690560569700 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:09:33 pandorasbox local1.notice CEVENT_APP[7622]: 1690560573784 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:09:37 pandorasbox local1.notice CEVENT_APP[7622]: 1690560577832 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 10:09:41 pandorasbox user.warn com.netdumasoftware.benchmark: websocket failed with '?:0: attempt to index a nil value' 132 Jul 28 10:09:41 pandorasbox user.warn lua: websocket failed with '?:0: attempt to index a nil value' 106 Jul 28 16:09:41 pandorasbox local1.notice CEVENT_APP[7622]: 1690560581904 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:09:45 pandorasbox local1.notice CEVENT_APP[7622]: 1690560585957 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:09:50 pandorasbox local1.notice CEVENT_APP[7622]: 1690560590020 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:09:55 pandorasbox local1.notice CEVENT_APP[7622]: 1690560595075 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:09:59 pandorasbox local1.notice CEVENT_APP[7622]: 1690560599149 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:10:03 pandorasbox local1.notice CEVENT_APP[7622]: 1690560603202 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:10:07 pandorasbox local1.notice CEVENT_APP[7622]: 1690560607255 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:10:11 pandorasbox local1.notice CEVENT_APP[7622]: 1690560611322 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:10:15 pandorasbox local1.notice CEVENT_APP[7622]: 1690560615372 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:10:20 pandorasbox local1.notice CEVENT_APP[7622]: 1690560620431 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:10:24 pandorasbox local1.notice CEVENT_APP[7622]: 1690560624478 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:10:28 pandorasbox local1.notice CEVENT_APP[7622]: 1690560628548 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:10:32 pandorasbox local1.notice CEVENT_APP[7622]: 1690560632626 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:10:36 pandorasbox local1.notice CEVENT_APP[7622]: 1690560636723 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:10:40 pandorasbox local1.notice CEVENT_APP[7622]: 1690560640790 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:10:45 pandorasbox local1.notice CEVENT_APP[7622]: 1690560645847 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:10:49 pandorasbox local1.notice CEVENT_APP[7622]: 1690560649896 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:10:53 pandorasbox local1.notice CEVENT_APP[7622]: 1690560653958 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:10:59 pandorasbox local1.notice CEVENT_APP[7622]: 1690560659051 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:11:03 pandorasbox local1.notice CEVENT_APP[7622]: 1690560663169 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:11:07 pandorasbox local1.notice CEVENT_APP[7622]: 1690560667211 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:11:11 pandorasbox local1.notice CEVENT_APP[7622]: 1690560671264 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:11:15 pandorasbox local1.notice CEVENT_APP[7622]: 1690560675314 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:11:19 pandorasbox local1.notice CEVENT_APP[7622]: 1690560679378 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:11:23 pandorasbox local1.notice CEVENT_APP[7622]: 1690560683428 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:11:27 pandorasbox local1.notice CEVENT_APP[7622]: 1690560687480 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:11:31 pandorasbox local1.notice CEVENT_APP[7622]: 1690560691563 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:11:37 pandorasbox local1.notice CEVENT_APP[7622]: 1690560697618 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:11:41 pandorasbox local1.notice CEVENT_APP[7622]: 1690560701685 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:11:46 pandorasbox local1.notice CEVENT_APP[7622]: 1690560706767 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:11:50 pandorasbox local1.notice CEVENT_APP[7622]: 1690560710856 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:11:54 pandorasbox local1.notice CEVENT_APP[7622]: 1690560714908 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:11:58 pandorasbox local1.notice CEVENT_APP[7622]: 1690560718959 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 10:12:00 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:12:00 pandorasbox user.emerg httpd: ****handle_get(926) 71 Jul 28 10:12:00 pandorasbox user.emerg httpd: ****handle_post(1441) 73 Jul 28 10:12:00 pandorasbox user.emerg httpd: ****handle_post(1454) 73 Jul 28 10:12:00 pandorasbox user.emerg httpd: ****handle_post(1470) 73 Jul 28 10:12:00 pandorasbox user.emerg httpd: ****handle_get(929) 71 Jul 28 16:12:03 pandorasbox local1.notice CEVENT_APP[7622]: 1690560723012 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:12:07 pandorasbox local1.notice CEVENT_APP[7622]: 1690560727058 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:12:11 pandorasbox local1.notice CEVENT_APP[7622]: 1690560731124 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:12:15 pandorasbox local1.notice CEVENT_APP[7622]: 1690560735178 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:12:19 pandorasbox local1.notice CEVENT_APP[7622]: 1690560739227 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:12:23 pandorasbox local1.notice CEVENT_APP[7622]: 1690560743312 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:12:27 pandorasbox local1.notice CEVENT_APP[7622]: 1690560747364 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:12:32 pandorasbox local1.notice CEVENT_APP[7622]: 1690560752470 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:12:36 pandorasbox local1.notice CEVENT_APP[7622]: 1690560756574 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:12:40 pandorasbox local1.notice CEVENT_APP[7622]: 1690560760624 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:12:45 pandorasbox local1.notice CEVENT_APP[7622]: 1690560765698 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:12:49 pandorasbox local1.notice CEVENT_APP[7622]: 1690560769750 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:12:53 pandorasbox local1.notice CEVENT_APP[7622]: 1690560773840 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:12:57 pandorasbox local1.notice CEVENT_APP[7622]: 1690560777886 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:13:01 pandorasbox local1.notice CEVENT_APP[7622]: 1690560781934 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:13:06 pandorasbox local1.notice CEVENT_APP[7622]: 1690560786041 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:13:10 pandorasbox local1.notice CEVENT_APP[7622]: 1690560790086 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:13:14 pandorasbox local1.notice CEVENT_APP[7622]: 1690560794134 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:13:18 pandorasbox local1.notice CEVENT_APP[7622]: 1690560798184 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:13:22 pandorasbox local1.notice CEVENT_APP[7622]: 1690560802271 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:13:26 pandorasbox local1.notice CEVENT_APP[7622]: 1690560806352 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:13:31 pandorasbox local1.notice CEVENT_APP[7622]: 1690560811406 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:13:36 pandorasbox local1.notice CEVENT_APP[7622]: 1690560816459 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 10:13:39 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:39 pandorasbox user.emerg httpd: ****handle_get(675) 71 Jul 28 10:13:39 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:39 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jul 28 10:13:39 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:39 pandorasbox user.emerg httpd: ****handle_get(926) 71 Jul 28 10:13:39 pandorasbox user.emerg httpd: ****handle_post(1441) 73 Jul 28 10:13:39 pandorasbox user.emerg httpd: ****handle_post(1454) 73 Jul 28 10:13:39 pandorasbox user.emerg httpd: ****handle_post(1470) 73 Jul 28 10:13:39 pandorasbox user.emerg httpd: ****handle_get(929) 71 Jul 28 10:13:39 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:39 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:13:39 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:39 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:13:39 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:39 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:13:39 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:39 pandorasbox user.emerg httpd: ****handle_get(675) 71 Jul 28 10:13:39 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:39 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:13:39 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:39 pandorasbox user.emerg httpd: ****handle_get(675) 71 Jul 28 10:13:39 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:39 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jul 28 10:13:39 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:39 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jul 28 10:13:39 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:39 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:13:39 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:39 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:13:39 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:39 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:13:39 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:39 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:13:39 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:39 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:13:39 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:39 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jul 28 10:13:39 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:39 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:13:39 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:39 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:13:39 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:39 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:13:39 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:39 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:13:39 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:39 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:13:39 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:39 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:13:39 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 16:13:40 pandorasbox local1.notice CEVENT_APP[7622]: 1690560820513 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(675) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(675) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(675) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:45 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 16:13:45 pandorasbox local1.notice CEVENT_APP[7622]: 1690560825627 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:13:49 pandorasbox local1.notice CEVENT_APP[7622]: 1690560829720 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 10:13:50 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:50 pandorasbox user.emerg httpd: ****handle_get(675) 71 Jul 28 10:13:50 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:50 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jul 28 10:13:50 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:50 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jul 28 10:13:50 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:50 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:13:50 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:50 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:13:50 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:50 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:13:50 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:50 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:13:50 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:50 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jul 28 10:13:50 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:50 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:13:50 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:50 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:13:50 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:50 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:13:50 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:50 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:13:50 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:50 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:13:50 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:50 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:13:50 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:50 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:13:50 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:50 pandorasbox user.emerg httpd: ****handle_get(675) 71 Jul 28 10:13:50 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:50 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jul 28 10:13:50 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:50 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jul 28 10:13:50 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:50 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jul 28 10:13:50 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:50 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:13:50 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:50 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:13:50 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:50 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:13:50 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:13:50 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 16:13:53 pandorasbox local1.notice CEVENT_APP[7622]: 1690560833855 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 10:13:54 pandorasbox user.emerg httpd: ****handle_post(1418) 73 Jul 28 16:13:57 pandorasbox local1.notice CEVENT_APP[7622]: 1690560837910 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 10:14:00 pandorasbox user.emerg httpd: ****handle_post(1470) 73 Jul 28 10:14:00 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:14:00 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jul 28 10:14:00 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:14:00 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jul 28 10:14:00 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:14:00 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:14:00 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:14:00 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:14:00 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:14:00 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:14:00 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:14:00 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:14:00 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:14:00 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jul 28 10:14:00 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:14:00 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:14:00 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:14:00 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:14:00 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:14:00 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:14:00 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:14:00 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:14:00 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:14:00 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:14:00 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:14:00 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:14:00 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:14:00 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:14:00 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:14:00 pandorasbox user.emerg httpd: ****handle_get(675) 71 Jul 28 10:14:00 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:14:00 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jul 28 10:14:00 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:14:00 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jul 28 10:14:00 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:14:00 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jul 28 10:14:00 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:14:00 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:14:00 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:14:00 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:14:00 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:14:00 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:14:00 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:14:00 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 16:14:02 pandorasbox local1.notice CEVENT_APP[7622]: 1690560842026 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:14:06 pandorasbox local1.notice CEVENT_APP[7622]: 1690560846105 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 16:14:10 pandorasbox local1.notice CEVENT_APP[7622]: 1690560850182 wl0 10:0C:6B:5C:8B:2D 1 0000 0000 0000 Driver -- E_LINK/16 167 Jul 28 10:14:11 pandorasbox user.emerg httpd: ****handle_post(1418) 73 Jul 28 10:14:11 pandorasbox user.emerg httpd: ****handle_post(1470) 73 Jul 28 10:14:11 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:14:11 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jul 28 10:14:11 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:14:11 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jul 28 10:14:11 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:14:11 pandorasbox user.emerg httpd: ****handle_get(746) 71 Jul 28 10:14:11 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:14:11 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:14:11 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:14:11 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:14:11 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:14:11 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:14:11 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:14:11 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:14:11 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:14:11 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:14:11 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:14:11 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:14:11 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:14:11 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:14:11 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:14:11 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:14:11 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:14:11 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:14:11 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:14:11 pandorasbox user.emerg httpd: ****handle_get(699) 71 Jul 28 10:14:11 pandorasbox user.emerg httpd: ****handle_get(411) 71 Jul 28 10:14:11 pandorasbox user.emerg httpd: ****handle_get(699) 71
Administrators Netduma Fraser Posted July 28, 2023 Administrators Posted July 28, 2023 Are you on OpenWRT at the moment as that doesn't look like a DumaOS log
Administrators Netduma Fraser Posted July 28, 2023 Administrators Posted July 28, 2023 Okay thanks, go ahead and try TFTP and see if that helps with it
ij4xs Posted July 28, 2023 Author Posted July 28, 2023 Well, there was an update to 1.0.0.68 from the 1.0.0.64 it was on. However, the tftp server window on the xr1000 was too small to get the firmware uploaded that way. Is there a trick to get the firmware uploaded that way?
Administrators Netduma Fraser Posted July 28, 2023 Administrators Posted July 28, 2023 1 hour ago, ij4xs said: Well, there was an update to 1.0.0.68 from the 1.0.0.64 it was on. However, the tftp server window on the xr1000 was too small to get the firmware uploaded that way. Is there a trick to get the firmware uploaded that way? It really just comes down to timing, you have to be pretty on it, it can take a few tries to get it right
ij4xs Posted July 30, 2023 Author Posted July 30, 2023 Okay, I was having trouble hitting the right timing on 1.0.0.68 that I installed nmap and with that version I'm not seeing a time that TFTTP is open at all. I get filtered while the router is 192.168.1.1 and return ping TTL of 100 then the switch ports turn off and when they come back it's still at 192.168.1.1 but with a ping return TTL of 64 and TFTTP port is still filtered. Then after a bit the router updates from 192.168.1.1 to whatever I have it configured for. Should I revert firmware to be able to TFTP or should I just give 1.0.0.68 a go?
