geo filter wont work
mike kontorousis
Thanks for the screenshots and extra info, that all looks OK. So when you're searching for a game in either FIFA or CoD, are you seeing any icons appearing on the map at all? Make sure you're zoomed all the way out on the map.
Are you still able to get into a game, just not on the servers you've selected with the filter radius?
It is working, it is getting you a game based on your settings - you won't always see multiple servers on the map being blocked/allowed
29 minutes ago, mike kontorousis said:
Ok no problem but why ive saw the videos of many servers and yellow triangles ....and if i rase the circle it connected with others servers???
It depends on the game, a game like FIFA tries one at a time, a game like CoD tries a lot so that was likely the one used in the video. Yes if you adjusted the circle it would allow/block more servers.
